Fax on Demand
sitig
Fax on Demand
Post by sitig »
Hi All
Does the Fax On Demand feature work on the 8450 Fax Server?
Cheers
Every adversity has within it a seed of an equivalent or greater benefit....
Re: Fax on Demand
What is that??
sitig
Re: Fax on Demand
Post by sitig »
Cav, this was a feature in 4635, the system requests the receiver fax number from the caller and then sends the content of the mailbox. I'm wondering whether this can be done on the 8450 Fax Server. Have been searching the Sagem site, but nothing much on it. Do you have any idea? Cheers
Re: Fax on Demand
I don't think so, at least not naturally...as FaxServer doesn't have any voice prompts and the architecture/integration is completely different you will need something else (like an IVR) to get that fax number and then send an email to the faxserver...
sitig
Re: Fax on Demand
Post by sitig »
Thanks Cav, we will need DTMF as well for this.
Re: Fax on Demand
Well the IVR application can ask for a number to dial (DTMF input) and then create an email inside the IVR (send_mail(DTMF@faxserver.domain.com))
sitig
Re: Fax on Demand
Post by sitig »
That's great info Cav, haven't worked on IVR before, well there's always a first time for everything aye. I will suggest this to our sales, I guess it will boil down to the cost.
OXE_4400
Re: Fax on Demand
Post by OXE_4400 »
IVR 4625TVK can work as fax on demand
Return to “OmniTouch 8450 Fax Software”
