Enable POE OMNISWITCH 6400
exoda
Hi, I am new in using omniswitch 6400 and I would like to enable POE. I have connected my laptop to the switch console but nothing is happening.
What should happen when my laptop is connected to switch console?
I've search internet and found to run a command "lanpower start" but i do not know how to run the command. The switch also include a document to download "OS6400 Base Software Module version 6.4.4.roi", i've download it but no application i can run.What is this download?
Can anyone show me the right direction?
thanks
thanks
one6f
Re: Enable POE OMNISWITCH 6400
from here you can find more information on OmniSwitch 6400 Hardware Users Guide.
If your laptop is connected to Console Port (bottom left on your switch) with Alcatel Console Adapter
The console port, located on the chassis front panel left, provides a console serial connection to the switch (no POE) and is required when logging into the switch for management purposes. You need an adapter RJ45/RS-232 DTE and console program such as microsoft HyperTerminal/HyperACCESS. You need to know if your switch is POE ready(OS6400-P24 and OS6400-P48) with 360W/510W power supply. You need an POE ready client such as IP phone, wireless LAN station, access point. It can be plugged directly into the Ethernet port(not Console!). From these RJ-45 the devices receive both electrical power and data flow. Connect this to any port on the switch except Console. In HyperTerminal after login/password you try:And then your POE client get power.
-> lanpower start 1-
mnehar
Hi here I have a problem with my poe switch Alcatel 6850 48 Ports is that we I activate POE with the command lan power start 1 I have an error message displayed
-> Lanpower start 1
THU 17 December 11:02:14: SYSTEM (75) alert message:
+++ I2cPoEReadReg: Unable to Read PD640xx I2C device 0x60
THU 17 December 11:02:14: LANPOWER (108) error message:
+++ SysReadPD690xx: i2c Read Failed !!
+++ Pd69_lpSysGetHWStatus: Invalid read!
+++ Unable to get HW Status pd69_lpStartNI
THU 17 December 11:02:22: SYSTEM (75) info message:
+++ The Port ID Causing i2c Bus Lockup is0
THU 17 December 11:02:22: SYSTEM (75) alert message:
+++ I2cReadOnBoardTemp: i2cRandomRead ERROR Temp Sensor = 0x96
THU 17 December 11:02:22: PRB-CHASSIS (102) error message:
+++ Error reading temperature sensor
so I can say it is a problem with AOS I proceed to upgrade to the
6.4.6.278.R01 Service Release, May 19, 2015 still the same problem
Thanks for your help
-> Lanpower start 1
did you have 6850-P48? Did PoE work before? Have you attached a PoE powersupply.
This switch is a lot of years old ....
mnehar
Yes, POE of switch work before knowing that the Cisco IP phone type are connected above
i use a new AOS but the same probleme display
For power supply i use a 360watt
if not, I have abnormalities on other switche of the same type like the empty interfaces that lights up all alone
sometimes I have DATA and sometimes i have telephony in poste user
Is the Cisco phone can be created this probleme and do i have to up firmware of phones ????
Thx....
Thx....
mnehar
can you help me ??? I have a lo tof switchs affected by this problem
Same phone like before the issue? Are there any changes as the problem occured first time (new phones, new phone image)?
I know that there are problems with cisco phones because they are speaking CDP. Alcatel uses standards like lldp.
Are there any "successfull" PoE devices (other phones, access points ....)?
mnehar
yes, it's not all the switches that are affected the other switch work normally with the same cisco phone
no changes to the firmware or phone it is me who moves to the customer
I did some research on this forum I found a guy used AOS 6.4.4.707.R01 he set himself some particular problem i2c failed
this can help me to have it may be it'll help me
Thx a lot Silvio for your HELP
