Problems on Win7 64bit, with acd setup
Jtmurphy76
Post by Jtmurphy76 »
When trying to activate the ACD services I get an error as per the pic.
Also a ftp error when starting stats manager.
I have enabled the ftp client and even switched off the firewall, but still get the error. Any advice
PuGZopf
Re: Problems on Win7 64bit, with acd setup
Post by PuGZopf »
Did you try to install and run after installation the application with rightMouse Admin rights?
On My system it is no Problem.
Wich ACD Version you use?
Return to “Applications”
