can I change permision at mtcl's $home ?
thkim81
Post by thkim81 »
Hi~~~
I have question in testing.
when I login at mtcl accounts, Can i change accounts permision at of mtcl $home directory ?
that means, I enter the command below
(1)eit_a> cd /DHS3bin
(1)eit_a> ls -l
(1)eit_a>total 116
drwxr-xr-x 5 root sys 4096 Sep 20 09:50 PKG
drwxrwxr-x 2 adfexc tel 4096 Sep 20 09:50 adfexc
drwxrwxr-x 2 root tel 4096 Sep 20 09:53 afe
drwxrwxr-x 2 client tel 4096 Sep 20 09:51 client
drwxr-xr-x 2 root tel 4096 Sep 20 10:12 com
drwxr-xr-x 3 root tel 4096 Sep 20 09:51 cpu_tools
drwxr-xr-x 2 root tel 4096 Sep 20 09:52 descript
drwxr-xr-x 8 root tel 8192 Sep 20 09:53 downbin
drwxr-xr-x 2 root root 4096 Sep 20 09:53 emulation
drwxr-xr-x 2 root tel 8192 Sep 20 09:53 fab
drwxr-xr-x 2 mtcl tel 4096 Sep 20 09:53 incid
drwxr-xr-x 2 root tel 4096 Sep 20 09:50 io2
drwxr-xr-x 3 root root 4096 Sep 20 09:56 lib
drwxr-xr-x 2 root root 16384 Sep 20 09:47 lost+found
drwxrwxr-x 4 mtcl tel 4096 Sep 20 18:14 mtcl
drwxr-xr-x 4 mtcl tel 4096 Sep 20 09:51 nmc
drwxr-xr-x 3 root tel 4096 Sep 20 09:50 oneshot
drwxr-xr-x 2 mtcl tel 4096 Sep 20 09:50 patches
drwxr-xr-x 2 mtcl tel 4096 Sep 20 09:53 rpm
drwxr-xr-x 2 root tel 4096 Sep 20 09:53 servers
drwxrwxrwx 4 root sys 4096 Sep 20 09:56 soft_install
drwxr-xr-x 2 root tel 4096 Sep 20 09:52 tel
drwxrwxr-x 2 2018 tel 4096 Sep 20 18:40 test
drwxr-xr-x 2 root tel 4096 Sep 20 09:53 x25
so, drwxrwxr-x 4 mtcl tel 4096 Sep 20 18:14 mtcl is change
drwxrwxr-x -> drwx --- ---
Is it possible ? If possible , anything is problem ?
stancu_adi
Re: can I change permision at mtcl's $home ?
Post by stancu_adi »
Yes...you can with chmod command.
But you must give mode rights not remove in order to work as before. If you remove some rights for owner or group it is possible that some processes to crash because cannot write or read from that directory.
BR
thkim81
Post by thkim81 »
thanks stancu_adi
and I request for above linux question with eSR.
so The answer is not recommend change at linux configuration.
I give to my customer answer and he is agree.
Return to “Linux tricks”
