LS 6224 - Debug mode password
Vipin
Post by Vipin »
One more 6224 down,,please help me.
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.0.12 Built 19-Oct-2006 09:07:37
OS6200 board, based on PPC8247
128 MByte SDRAM. I-Cache 16 KB. D-Cache 16 KB. Cache Enabled.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
100%
Decompressing SW from image-1
100%
OK
Running from RAM...
*** Running SW Ver. 1.7.1.7 Date 12-May-2010 Time 16:32:04 ***
HW version is 00.00.01
Base Mac address is: 00:12:cf:ae:65:a0
Dram size is : 128M bytes
Dram first block size is : 98304K bytes
Dram first PTR is : 0x2000000
Flash size is: 16M
01-Jan-2000 01:01:04 %CDB-I-LOADCONFIG: Loading running configuration.
01-Jan-2000 01:01:04 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
CPLD revision: 1.00
PCB revision: R-0A
Slot 1 - OmniStack LS 6224P HW Rev. 1.0
-- Unit Number 4 Slave --
01-Jan-2000 01:01:17 %INIT-I-InitCompleted: Initialization task is completed
>PoE software version:
H.W. Version 0: Identifies the PCB version.
Full S.W. version is: Prod#.SW Ver.Param# - 0.505.4
Build Num 2, Internal SW 341.
The same version ...
PoE device version:
PoE Device 0, hw Version: 2. 12 ports.
PoE Device 1, hw Version: 2. 12 ports.
Unknown parameter
May be one from the following list:
debug help
>debug
Enter DEBUG Password:
Bad Password
slixxboy
Re: LS 6224 - Debug mode password
Post by slixxboy »
- what is your concern sir? would you like your switch to be boot in normal?
- try to back read sir or search for 6224 stack
- or http://alcatelunleashed.com/viewtopic.p ... 224#p59212 and
http://alcatelunleashed.com/viewtopic.p ... 224#p64660
regards,
Q-Ant
Post by Q-Ant »
OK
Running from RAM...
Flash size is: 16M
CPLD revision: 1.00
PCB revision: R-0A
Shouldn't you have boot 1.0.0.13 if trying to run image 1.7.1.7?
Also this switch was stacked, please revert to factory setting s first.
Return to “OmniStack LS 6200”
