How can to configure option 82 on Omniswitch 6400
oleola
Post by oleola »
Hi everyone,
For our Network System, We need to use ipoe to configure DHCP option 82, so below, when I configured option 82, it doesn't work. Could you please help us to check this issue ?
Thanks so muck for your support.
ip helper agent-information enable
ip helper dhcp-snooping option-82 format ascii user-string "Cus_A" base-mac system-name vlan interface delimiter " "
vlan 105 name "ipoe-test"
vlan 105 802.1q 1/24
vlan 105 port default 1/1
The Circuit-id send from DHCP Discover packet Omnniswith hasn't received
one6f
Re: How can to configure option 82 on Omniswitch 6400
Post by one6f »
Do you already looked here?
oleola
Post by oleola »
The feature DHCP option 82 is working well, Thanks one6f for give me the link.
oleola
Post by oleola »
Hi all,
I have had the same issue seen. We need to use PPPoE with 7 Parameters like DHCP option 82, so how can OS 6400 make it ?
THanks!
one6f
Post by one6f »
I thought there is no pppoe support on 6400?
Return to “OmniSwitch 6400”
