In OmniVista 4760.5.1.06.03 when I try to get a report> Traffic Analysis> Trunk Groups> Summary Report or Detailed Report> with period last month, the same is generated without any data, although other reports relating to the same month generated correctly. Is there any explication for this?
Report whithout data
Re: Report whithout data
what is the user that you login in 4760?
the default user for OmniVista4760 is 'adminnmc'
you created a new user called administrator?
Sorry!! The user type is administrator but the user is adminnmc.
can you please check the following settings?
see attachment
see attachment
First of all do you have "PastTimePerformance" license on 4760 and "Traffic Observation" license on OXE?jaspion wrote:Hello,
yes,
OXE:
39 Performance = 150
4760:
; list of applications and capacities
[Modules]
Configuration = 550
Alarms = 550
Topology = 0
Accounting = 550
AccountingMonitoring = 0
PastTimePerformance = 550
VoipPerformance = 550
Directory = 0
NmcClients = 1
Subscribers = 550
Security = 0
TicketCollector = 0
Audit = 0
SipManager = 0
OXE:
4760:
[Modules]
Configuration = 550
Alarms = 550
Topology = 0
Accounting = 550
Directory = 0
NmcClients = 1
Subscribers = 550
Security = 0
TicketCollector = 0
Audit = 0
SipManager = 0
I faced this problem with a different situation. first all reports were sent complete and right for 3 months, then it sends empty reports.
I checked all the settings above and they are right already, Any suggestions??
