Dear all
I want change headset volume..
because agent don't wanna heard to customer from another agnet noisy.
so I change config at Series 8&9 Set Audio Parameters -> Handset Reception Audio Paths -> |
| Level 1 : -6 |
| Level 2 : -3 |
| Level 3 : 0 |
| Level 4 : 3 -> 0 |
| Level 5 : 6 -> 0 |
| Level 6 : 9 -> 0 |
| Level 7 : 12 |
| Level 8 : 15 |
| Level 9 : -127 |
| Level 10 : -127 |
| Level 11 : -127 |
| Level 12 : -127
so I control noisy but I don't know what's mean LEVEL 4 , LEVEL 5 , LEVEL 6
what's mean these LEVEL ? pls tell me what's means.
thanks
- frank
Re: Series 8&9 Set Audio Parameters
LEVELS are the levels every time you push the + or - on the keyboard.
If you press let's say 10 times the - , and you are all the way down, you would be at level 1.
Every time you are going to push + , your audio will increment , and you will be at the next level.
Got it ?
Got it ?
thkim81
thanks frank
so LEVELs are Ip phone's volume MIN and MAX indicate ?
If I change LEVEL 1 : -6 -> 0 IP phone user volume can change make the most of 0db ?
Is that right ?
Is that right ?
- frank
Correct.
The phone needs to reboot to take this in account.
miranda_veracruz
what about audio-parameters at UA-Devices?! Does it work immediately or do I have to make a bascul?!
