OXE Rel 7.1 , INTIP2 is not INSERVICE,
Managed the Netadmin, Ethernet Parameter, lanpbxbuild, reboot, INTIP2 v24 - shows that FTP not responding..!!
any idea..?
Thanks..
INTIP2 - TFTP failure
- Konstantinos.E
mujib.alu
Re: INTIP2 - TFTP failure
Hi Kons..
many time,........No effect..........!
Board Iniat running 1 as usual...!!
any idea..?
any idea..?
- Konstantinos.E
the intip is INTIPB or A ?INTIPB-GD parameters the mac adress is checked by tftp?if yes set it to false
Alca_holic
mujib.alu
Hi Kons,
Its a INTIPA for SIP trunk, also "the mac adress is checked by tftp?" : False already..!!
Also I tried lanpbxbuild -auto (as per the unleashed old case)
So I have to create New DB and formalities...? or Load the Software also..?
Please advice..?
Please advice..?
- Konstantinos.E
hi
show us the incidents on the intip when it boots..
also the intip is in the same subnet as the cpu?
do u have static configuration?
dhcp enabled?
ip domains?
exlplain your configuration...
dhcp enabled?
ip domains?
Alca_holic
