Have problem with the connection to oxo.am able to connect to internet services.But cannot connect to database through pbxk1064 password.
tried the lola.does not connect either.Any possibilty to connect.
Lola -CPU connection
lola- cpu
I am able to connect to through https://192.168.92.246/services/webapp/monitor/
using the installer password pbxk1064.Here is copy of system monitor,
Monitor System start
--- CPU TYPE: MAIN ---
--- Start of BIOS ---
Succeeded
--- Start of Linux kernel ---
Operating system: Linux 2.4.17-rt3.1
Succeeded
--- Ramdisk initialization ---
Succeeded
--- Hardware detected ---
CPU: GenuineIntel Pentium III (Coppermine)
CPU speed: 100 MHz
RAM size: 256 Mb
Flash size: 30795 kb
Xmem flash: not present
Hard disk: present
Hard disk size: 38153 Mb
Hard disk manufacturer: TOSHIBA MK4032GAX
--- Start of the software ---
++ 8 ++ Start of Init of telephony ++ 8 ++
Type of reset : WARM
Main licence Status : open
CTI licence Status : open
++ 7 ++ Init controller Master ++ 7 ++
Power supply Status : BATTERY
Dld DSP 0 : OK
Type of Backpanel : MEGA RACK 3
Dld DSP 1 : OK
Power supply Status : MAIN
++ 6 ++ Detection of boards on controller Master ++ 6 ++
Slot : 1 - Board : EBZ_1_LH - hb in slot : 1
status : accepted
Slot : 2 - Board : APA - hb in slot : 1
status : accepted
FAN2 Status : OK
FAN2 Status : OK
++ 5 ++ Init controller Sat 1 ++ 5 ++
++ 3 ++ Init controller Sat 2 ++ 3 ++
++ 1 ++ End of Init of telephony ++ 1 ++
- > Creation of virtual boards :
Slot : 90 - Board : XRA - hb in slot : 1
status : accepted
Slot : 91 - Board : IVPS - hb in slot : 1
status : accepted
Slot : 99 - Board : VIRT_MEDIA - hb in slot : 1
status : accepted
Comment : no restore, call handling is available
++ 0 ++ telephony is running ++ 0 ++
+ CPU TYPE : MAIN
ANV number : 3EU23006ACAC 03
db1 : wan
db2 : absent
db2 : absent
db3 : afu
db4 : absent
CPU speed: 700 MHz
RAM size: 256 Mb
Flash size: 32 Mb
Hard disk: present
Hard disk manufacturer: TOSHIBA MK4032GAX 3EU23006ACAC 03
Detected sets :
UA : 0
MUA : 0
IBS : 0
Z : 3
mobile set : 0
V24 : 0
TA : 0
S0 : 0
AOM : 0
Detected trunks :
T0 : 0
E1 : 1
T1 : 0
DASS2 : 0
DLT0 : 0
DLE1 : 1
TRUNK_IP : 0
ANALOG : 4
PCM : 0
T1CAS : 0
DECT : 0
In telephony services db2 and db4 are shown absent.
from the monitor info,is there a way to connect to telephony services database.
When try to connect through the expert option,one time the connect status
bar (blue )appears and stays stationary until no connection error screen comes up.
Succeeded
Succeeded
Succeeded
CPU speed: 100 MHz
RAM size: 256 Mb
Hard disk: present
Dld DSP 0 : OK
Dld DSP 1 : OK
status : accepted
status : accepted
FAN2 Status : OK
FAN2 Status : OK
status : accepted
status : accepted
status : accepted
+ CPU TYPE : MAIN
db1 : wan
db2 : absent
db2 : absent
db3 : afu
db4 : absent
CPU speed: 700 MHz
RAM size: 256 Mb
Flash size: 32 Mb
Hard disk: present
Detected sets :
UA : 0
MUA : 0
IBS : 0
Z : 3
mobile set : 0
V24 : 0
TA : 0
S0 : 0
AOM : 0
Detected trunks :
T0 : 0
E1 : 1
T1 : 0
DASS2 : 0
DLT0 : 0
DLE1 : 1
TRUNK_IP : 0
ANALOG : 4
PCM : 0
T1CAS : 0
DECT : 0
lola- cpu
https://192.168.92.246/wca/login/index. ... authorized
What is default password for wca?
et
What type of programm you use to connect to OXO telephony - PM5 or OMC, and which version? From release 5 of OXO you should use OMC. And what does it mean - "connect to database"???javascript:emoticon(':?:')
Question
For login and password for WCA you need use that data of subscriber, created before in Internet Services, and have right to use WCA. There is no any default password.
Question
lola-cpu
I am using OMC r5.I want to administer PBX trough the Expert login screen.When i connect with installer password pbxk1064,the status bar which in a normal situation flashes few time before get connected.But in my case
this blue bar comes and stays there until error screen comes.
et
lola -cpu
But i don't have any problem with connection to other oxo units.
I want to reload the software through but not able to do so.
OXO system responds to internet services ,when i use the internet broswer.
From my last post which includes System Start Monitor.I am able to use the analog interfaces SLI with default numbers(110,111,112,113).But can not make changes to program.
et
