UC Mobility for BlackBerry
nalinggo
Post by nalinggo »
UC : 6.2.000.104b
OXE : h130131b
MyIC client : 3.5.5.4
After installing the client to the BB set,
I'm able to access the imei.xml, CommonConfig.xml only using - Hotspot browser.
If using normal Internet browser i'm not able to access both files.
I'm able to ring to BB tandem set calling oxe number.
After i configure the MyIC client by adding ics server address:
eg:- dns.test.com and
username and password
Then i clicked on "RELOAD VALUES FROM ICS SERVER" nothing was downloaded to my BB set.
*he UC Mobility feature is used within the organization, which data is used to connect to ics and the voice will go through GSM. No BES server in the infra.
Any advice?
Re: UC Mobility for BlackBerry
I think that BES is mandatory, BIS is not supported
nalinggo
Post by nalinggo »
cavagnaro wrote:I think that BES is mandatory, BIS is not supported
I wonder do you have any documents that shows that BES is a must? I only found BES server is mandatory if using outside organization.
Sulman A
Post by Sulman A »
yes BES is must is must for the solution, I tried connecting to BES via wifi even this didnt work.
