Flash Time on analog telephone
anbani
Post by anbani »
Hi all,
I have Oxo R8, and i want to change flash time on the analog phone. I read document and see 5 parameters: (exp: 00 0C 00 30 00 16 00 28 00 05)
Earth button validation Timer (00 05 =40ms)
Corresponds to digit detection Timer (00 28 =320ms)
Corresponds to Flashing detection Timer (00 16=176ms)
Corresponds to "OnHook2W" timer (00 30 =384ms)
Corresponds to "OffHook2W" timer (00 0C =96ms
Now, i want to change 600 (or 300 ms, 8ms step). So, i select " Corresponds to Flashing detection Timer" from "00 16 = 176 ms" to "00 4B = 600 ms". So when set Flash Time on analog phone only choose " Flashing detection Timer" in 5 parameters? Or change all parameters?
doublevand981
Re: Flash Time on analog telephone
Post by doublevand981 »
hi
i am looking for this answer,too.
Any pro had experience on this pls share with us!
anbani
Post by anbani »
Hi doublevand981,
Yesterday, i received OXO R8.0 and i tried to change "Flashing detection timer" from 176ms to 300ms, Flash time of the analog phone has ok!
doublevand981
HI anbani,
can you share me your document? i dont understand what is value for this paramter equal 300ms
email: doublevand981@yahoo.com
thanks
anbani
Post by anbani »
Hi doublevan,
The first: 300/8=37(decimal) (100ms, 600ms...)
The second: change 37 (decimal) to 25 (hex). You can use Calculator on Window 7
Now, You change the Flashing detection Timer (00 16=176ms) to (00 25). Then you restart pabx (note: warm reset).
doublevand981
Why you use 300/8... what is 8 here ?
thanks
giovanni.attolini
Post by giovanni.attolini »
8 represents the unity of time used to calculate the flash time. For example, if you need to change the flash time to 600ms, you must do 600/8 = 75, so you put 75 on the field in decimal mode, or transform the 75 to hex and put in the hex mode. For each unity of the field value you have 8ms of flash time.
Giovanni A. Attolini
doublevand981
thanks you so much, Giovanni Attolini
i never know this before.
elias_ruiz_diaz
Post by elias_ruiz_diaz »
Hi! i wanna use the flash button for panasonic ts500 but it does't work this configuration "00 0C 00 30 00 4B 00 28 00 0C" if something is wrong please help me, i'm from paraguay, the configuration it isn't by zones? please, if is something to change, please tell me! thanks!
Return to “Configuration”
