TYPE OF NUMBER (TON)
rafaelsnsa
Post by rafaelsnsa »
How to change the TYPE OF NUMBER (TON) parameter in OmniPCX Office?
Thank's
Rafael Saraiva
Re: TYPE OF NUMBER (TON)
You want like national, unknown, International,...etc? If so ExtNumForm label in Other labels.
rafaelsnsa
Yes. Is needed reboot in the system after changes?
rafaelsnsa
what's the codes for each option?
rafaelsnsa wrote:what's the codes for each option?
See this:
noteworthy r80 ed2.pdf
Return to “Configuration”
