Not login via console cable
serviceos
Post by serviceos »
6850-u24x
reports error:
SAT MAY 21 19:35:17 : CONFIG (66) warning message:
+++ ERROR: Failed to pre-parse configuration file </flash/working/boot.cfg>
SAT MAY 21 19:35:19 : HSM-CHASSIS (101) info message:
+++ T1:Ni Insertion detected on slot 1
+++ ==== HSM === Power Supply 1 is OPERATIONAL
SAT MAY 21 19:35:41 : WEB (69) info message:
+++ WebView SSL/RSA file-based certificate set-up successful!
login :
SAT MAY 21 19:35:45 : CCM-CHASSIS (100) info message:
+++ === CCM === csCcmEoicFunc: send CCM_CSM_EOIC OK
SAT MAY 21 19:35:45 : CSM-CHASSIS (103) info message:
+++ == CSM == CMM startup completed
SAT MAY 21 19:35:46 : CLI (67) info message:
+++ Starting new CLI console session
asic rev BCM56504_B2 cpld 0019 db_cpld_ptr 00 uboot ver 6.1.5.479.R01 miniboot v
er 6.1.5.479.R01
SAT MAY 21 19:36:10 : INTERFACE (6) info message:
+++ NIs are ready 5425
No request for login password,
how to enter the login password?
cedric1
Re: Not login via console cable
Post by cedric1 »
hello
If you typ enter and nothing happen on your console, you have to check console settings of your pc, etc
see viewtopic.php?f=192&t=17191
Cedric
