Dial tone problem
bkaya
Dial tone problem
Post by bkaya »
Siemens pbx and Oxo connects on voip to eachother but callings from Siemens to oxo on voip the client dont hear any ring tone.Anyone know the reason please help..
Thnks.
henk1964
Post by henk1964 »
Do you have audio?
Is the phone ringing?
Is the only problem that the caller does not hear the ringing tone?
Please give more info..
bkaya
Post by bkaya »
Yes, the only problem is caller doesn't hear the ringing tone.
BTW thanks for your answer.
Do you use Direct RTP? if you not use direct RTP, called user site must generate local ring back tone (after receiving ALERT message).
Return to “MAIN”
