OXE lost configutarion
sorourkhaled
Hello everyone, I am a beginner
I have bought OXE on eBay with the following configuration
1x GD (Gateway driver processor unit) should have IP 10.44.20.22
1x CS `(Call server processing unit) should have IP 10.44.20.20
4x UAI 16-1 1x SLI 16-1 1x PRA-T2 1x BRA 4 (=4 ISDN)
1x 4059 TA MMK 3AK17095ABAA-02 Attendant Console
1x 4049 MMK Keyboard 3AK17043ABAB
When the system starts up this is what happend
GD lights up but never reach the position of working and it seams it lost the IP address
Also when connecting a phone or the attendant console it gets no power up
Two lights are on (the power lamp,CPU and the Module lamp) and that is it the FAN lamp never starts
How can I get this to work or what is the default IP address ?
CS Starts and I could connect via the browser to IP 10.44.20.20 and see the Omnivista screen
I am not able to login because I don't have the password (the login name seams to be mtcl but no password)
Is there a way to reset the password without loosing the license ?
Thanks,
Thanks,
- tot3nkopf
Re: OXE lost configutarion
You have the system documentation available on this website. This is a good start for you.
Also there is a password recovery procedure available (search is your friend).
Tips:
You need a serial cable in order to connect to consoles on both GD (to configure IP parameters) and CS
GD needs to be connected to CS in order for media gateway to work: check this forum for lanpbxbuild (command on CS --> lanpbxbuild -auto).
Tips:
sorourkhaled
Many thanks for the reply, I will search more about the lanpbxbuild
Do you have any link for password recovery procedure, I have only the Omnipcx but not the server,
- tot3nkopf
You have both. You just don't know yet...sorourkhaled wrote:Many thanks for the reply, I will search more about the lanpbxbuild
- Konstantinos.E
Maybe we should make a bid tot3nkopf on ebay...maybe could be good bussines...
Alca_holic
- tot3nkopf
There are for sure. I have some friends in second hand business that buy lots of goodies from e-bay.Konstantinos.E wrote:when you buy from e buy you dont buy technical support...
- Konstantinos.E
password recovery ONE,password recovery TWO,password recovery THREE......sold to the user mtcl!
procced with your money transfer on PAYPAL.
Alca_holic
sorourkhaled
I mean the PC server, the CS card is there, working and the IP is correct, but I have no password,tot3nkopf wrote:You have both. You just don't know yet...sorourkhaled wrote:Many thanks for the reply, I will search more about the lanpbxbuild
Whoever is willing to help we can do that on skype, just let me know the hour price and I pay with PayPal,
Search "Forget OXE 9.0 password" - topic where described how reset root password.
And "root password recovery"
