Web Directory Configuration
aflores
Post by aflores »
Hello, I´m try to make it work the Web Directory without any result.
I already create an User, get in to the Web Brownser the 4760 Server address / Directory Access.
I Autenticated with the created user and my associated station, but when trying to search any name thereis no result.
I´m not 4760 expert, I´m just a very basic 4760 administrator so, I will apreciated any help to make it work.
This is for a client in a ABC Network (9 Site) that want to use this 4760 tool.
AFLORES
cvjo
Re: Web Directory Configuration
Post by cvjo »
Your question is not clear. What is the issue? Let us know the step by step procedure you did for configuration...
ACSE OXE
ACSE Omnivista 4760
Developer 8770
aflores
Post by aflores »
Hello cvjo.
There is a 4760 Facility call Web Directory right?.
The client want to use it most for the users that don't have phone set with alphabetic keyboard (analog, 4004, 4010,).
Following the manual I got into the Ip@ of the 4760 with the web bronwser
I select Web Directory
I get in with an new account created (also get in with the AdaminNmc account with no succes either)
Associated and extension number
BUT,when I search some user by name, I got nothing.
So, What have to be done to Use the Web directory to search by name other user a call them?
AFlores
alex
Post by alex »
First of all you need license for that.
Second this feature shoild be enabled.
Third this Wed directory should be created - it is not created automatically. You must create country, city, company etc. Then you point out where PABX data be assighed.
Check section 2.2 "Company tab" in 4760 Administration manual
aflores
Post by aflores »
Hello Alex, thats exactly what I am asking, How to enable?.
The 4760 has the licences so I will follow what you mention a let you know.
AFlores
alex
Post by alex »
aflores wrote:thats exactly what I am asking, How to enable?.
Check section 2.2 "Company tab" in 4760 Administration manual.
It is a bit complicated but you have to read it to understand because there are too many "directories" in 4760.
First
In "Company tab" you create a structure of your organisation.
Second
2.2.2.3 Location of the Items Automatically Created in the Company Directory
You can specify for each network, subnetwork, or PCX (OmniPCX 4400 and Alcatel-Lucent
OmniPCX Enterprise CS only), the location where you want the entries to be created
automatically. You can specify this in the System directory via the Location for automatic
creation attribute
for networks, subnetworks, and PCXs.
There you point to organisation structure you created.
Then do a complete sync.
After that you should have web-directory available.
aflores
Post by aflores »
Hello ALex, finally I could make it work.
Thanks a lot for your help.
AFlores
alex
Post by alex »
aflores wrote:Hello ALex, finally I could make it work.
Congrats! :)
Return to “4760”
