Hi all,
do you know anyone why vrrp toggled on the one site(Backup to Master) although the master was not down(and don't toggled).
The linkagg interfaces were not DOWN and there are no errors/discards.
I've s83(6x6850) -> static LACP -> s88(8x6850)
s83>
! Link Aggregate :
static linkagg 2 size 2 admin state enable
static agg 1/50 agg num 2
static agg 2/50 agg num 2
! VRRP :
VRRP 2 2504 DISABLE
VRRP 2 2504 PRIORITY 254 PREEMPT INTERVAL 1
VRRP 2 2504 ADDRESS 10.212.1.1
VRRP 2 2504 ENABLE
VRRP 5 2512 DISABLE
VRRP 5 2512 PRIORITY 254 PREEMPT INTERVAL 1
VRRP 5 2512 ADDRESS 10.212.6.1
VRRP 5 2512 ENABLE
s88>
! Link Aggregate :
static agg 1/26 agg num 2
static agg 3/49 agg num 2
! VRRP :
VRRP 2 2504 DISABLE
VRRP 2 2504 PRIORITY 100 PREEMPT INTERVAL 1
VRRP 2 2504 ENABLE
VRRP 5 2512 DISABLE
VRRP 5 2512 PRIORITY 100 PREEMPT INTERVAL 1
VRRP 5 2512 ENABLE
s88> show log swlog timestamp 05/11/2011 00:00
WED MAY 11 00:01:38 2011 VRRP info VRRP toggled once in the last minute. VRID=2
WED MAY 11 00:01:38 2011 VRRP info VRRP toggled once in the last minute. VRID=5
WED MAY 11 06:09:13 2011 VRRP info VRRP toggled once in the last minute. VRID=2
WED MAY 11 06:09:13 2011 VRRP info VRRP toggled once in the last minute. VRID=5
s88> show vrrp 2 statistics
Virtual Router VRID = 2 on VLAN = 2504
State = Backup
UpTime (1/100th second) = 39565221
Become master = 72
Advertisements received = 39050221
Type errors = 0
Advertisement interval errors = 0
Authentication errors = 0
IP TTL errors = 0
IP address list errors = 0
Packet length errors = 0
Zero priority advertisements sent = 0
Zero priority advertisements received = 1
Mike
VRRP toggled
cedric1
Re: VRRP toggled
hello
If backup toggled it is because he didn't get vrrp multicast in the right time he expect to get it.
This type of message can show you issue on your interconnect between sw83 and sw88.
Try to put VRRP 5 2512 PRIORITY 100 PREEMPT INTERVAL 1 with a delay interval to 5 and see if pb continue, if yes you have issue on line interconnect.
In my prod network I have a lot of vrrp instance and no message of toggled vrrp.
I assume there is no trap for "stp root chane" for vlan using this vrrp instance.
Cedric
Cedric
one6f
Re: VRRP toggled
Hi cedric,
thanks for the replay. I'll test with 2 sec
sw83: VRRP 5 2512 PRIORITY 120 PREEMPT INTERVAL 2
sw88: VRRP 5 2512 PRIORITY 100 PREEMPT INTERVAL 2
I mean 5 sec. is perhaps to much?
Can you, please, take a look at VRRP behavior of the Master. I have sniffered with Wireshark on both uplinks(port mirroring):
sw83 10.212.1.2 Master
104975 2011-05-22 22:12:47.589245 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
104978 2011-05-22 22:12:48.589207 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
104981 2011-05-22 22:12:49.589108 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
104986 2011-05-22 22:12:53.172007 10.212.1.3 224.0.0.18 VRRP Announcement (v2)
104988 2011-05-22 22:12:53.373444 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
104990 2011-05-22 22:12:53.373630 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
104992 2011-05-22 22:12:53.373998 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
104994 2011-05-22 22:12:53.595252 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
104997 2011-05-22 22:12:54.589769 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
sw88 10.212.1.3 Slave
64278 2011-05-22 22:12:47.589274 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
64281 2011-05-22 22:12:48.589227 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
64284 2011-05-22 22:12:49.589128 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
64289 2011-05-22 22:12:53.172004 10.212.1.3 224.0.0.18 VRRP Announcement (v2)
64291 2011-05-22 22:12:53.373455 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
64293 2011-05-22 22:12:53.373654 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
64295 2011-05-22 22:12:53.374016 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
64297 2011-05-22 22:12:53.595272 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
64300 2011-05-22 22:12:54.589788 10.212.1.2 224.0.0.18 VRRP Announcement (v2)
I found it very strange that the Master sends 3 advertisements at the same second?
cedric1
Re: VRRP toggled
hello
There is 2 strange things :
104986 2011-05-22 22:12:53.172007 10.212.1.3 224.0.0.18 VRRP Announcement (v2) --here we have vrrp toggling as after 3*interval timers sw83 didn't send vrrp to sw 88 -> so sw88 send now vrrp advertise
64289 2011-05-22 22:12:53.172004 10.212.1.3 224.0.0.18 VRRP Announcement (v2) -- strange !!
So there is issue in vrrp send by sw83, should be the same if sw88 is master (perhaps to test). So we realy see that packet are not send out sw83. There is like a desynch.
FYI : I think to change time you need to make a disable / enable of vrrp instance.
So before opening a case, wich sw are you using, and next go for last one.
Did your pb come directly after you configure vrrp ?
one6f
Re: VRRP toggled
Hi cedric,
thank you for reply.
Both switches with vrrp were running the same v.6.3.1.1176 for more than one year without this issue.
The issue is seen always at the same time period at night.
I tried to change priority so that the VRRP master was on sw88 and no toggle was to be seen (all ok).
Just when sw83 becom the master the issue is back again.
There are 2x10Gb LAG and are not fully utilised.
Next service/maintenance day I will try to change time to 2sec.
Thank you
Mike
Thank you
Mike
cedric1
Re: VRRP toggled
Trace you take show that charge on link is not issue, as we see vrrp packet are not send out the device sw83.
I suggest before making 2s change you make a reboot of sw83.
As you know, before opening a ticket you have to be in last code if pb is not solved after reboot.
Let us know end of the story
cedric
cedric
