trunk line right choice when outgoing call
anbani
Post by anbani »
Hi all,
I have OXO R8, i want to configure fax line, such as: extension 303 when outgoing call seizure trunk line 1 (025437467, ARS prefix), dislay fax number right. I use APA8 Board. Many thanks!
Konstantinos.E
Re: trunk line right choice when outgoing call
Post by Konstantinos.E »
hi
if you use apa8 mean that you have analog trunks and you dont have did translation i am i right?so manage the ars table witch prefixs go out from which trunk group.read the manual how will you configure the ars table.
Or connect the fax number (line)str8 to the fax machine.
hope it helps
Alca_holic
anbani
Post by anbani »
Hi Kons,
Thank you, i used APA board (non DDI.) of OXO. I want to configure fax line same as OXE (non DDI). I use ARS and declare trunk group ( trunk group 88, trunk line 1 - Fax) and entity of fax's extension (entity 8), then assign entity 8 to trunk group 88. i check outgoing call display fax line right! But with OXO, i want to so...?
Any idea!
Use overflow feature in ARS and different Link Category for normal users and fax. One will have in sharing matrix access to main TG and the other only access to Fax TG.
Return to “Configuration”
