Any one can help me, in OTOFS Rel 5.X - the incoming fax receives twice ..
Incoming fax received twice..
usmanikf
Re: Incoming fax received twice..
Dear ...
Thanks for the professional n technical advise and we must be giving such solutions for the customer as well....)))))
krzysioD
my glass orb tells me: you have a trunk port on switch and plugged into that port your otuc / 8450.
Or any other thing, without a knowleage how you make test and what is your config, it's just a guess.
usmanikf
The Issue has been resolved, thanks for the support and advise....
And as you also like to share and help...which was the solution?
usmanikf
In incoming routing table - Directory lookup rule was added twice....
letacla.alcatel
So finaly you remove the "carbon sheet" from routing table right...!! As a professional n technical..!!
