Cannot connect to PowerCpu using OMC Serial
wallacezammit
I am trying to connect serially (using OMC rel8) to a powercpu but cannot. I tried it with different Powercpu's and from different pc's but still couldnt work. I checked the cable just in case but it's ok.
Was there any change to connect serially to a powercpu?
Wallace
Wallace
Re: Cannot connect to PowerCpu using OMC Serial
At first - connect V24 (115 kbits) and use some terminal programm - if you will see how OXO started (many message like process and so on started) - you need to change V24 mode
wallacezammit
With hyperterminal 115kbits I can see activity going on. I also tried both ways with swap_serial but still couldn't connect serially.
Did you manage to connect serially with a Powercpu?
julysavov
I also have the same problem and can't find the solution!
ae225
Have the same problem and submit an eSR to ALU. Been 2 weeks and now in observation sheet with R&D.
Understand that there are similar cases reported. So, hang in there. A solution will be found soon.
Rgds.
Rgds.
ae225
nope...OS Status:treatment in progress
Rgds.
Rgds.
wallacezammit
still no news on this issue?
ae225
no, unfortunately. Its still 'treatment in progress' status.
Btw,I'm using usb to rs232 with v24 cable and it fails to login. But a reseller manage to use built-in com port to login with success on same machine and
with my v24 cable! Back in office, I use another notebook with built-in com but no luck. what's wrong with OXO and its firmware?!
