ERROR : Synchronization Commands will not be accepted due to low flash . Remove unwanted files
Between the upgrade session I had a crash with loaded 6.3.4 firmware because the copy-part of scp command (from outside to the switch)s not supported and the switch crashed (which is verifiable to this scp use) and produced a Crash.pmd.
I removed this file, but if I upload the Image-Files the switch shows the low flash messages.
Actually:
-> freespace /flash
/flash 1871872 bytes freeCode: Select all
drw 512 Mar 8 15:39 ./
drw 512 Mar 8 15:42 ../
-rw 1597113 Apr 17 2007 [color=#800040]K2diag.img [/color]
-rw 1872962 Mar 8 13:30 K2os.img
-rw 2869855 Mar 8 13:31 Kadvrout.img
-rw 17817670 Mar 8 13:32 Kbase.img
-rw 5512076 Mar 8 13:34 Keni.img
-rw 4257 Apr 17 2007 [color=#800040]Krelease.img[/color]
-rw 623975 Mar 8 13:34 Ksecu.img
-rw 1396 Mar 8 15:03 boot.cfg
-rw 3437 Mar 8 13:33 Kencrypt.img
