Below is the Network Logical Diagram of mine existing setup
FW1 (192.168.16.2) <=====> CSW1 <====> ESW1
FW2 (192.168.16.3) <=====> CSW1 <====> ESW1
FW3 (192.168.16.4) <=====> CSW1 <====> ESW1
My Core Switch (CSW1) consist of a few VLANs and I am trying to using Policy Based Routing to divert the different VLAN to their specific FW for traffic to go out.
I had setup a client under the Guest VLAN (192.168.14.0) at the Edge switch (ESW1).
I had setup a client under the Student VLAN (192.168.10.0) at the Edge switch (ESW1).
Before I put in the Policy Based Routing (PBR), pinging to all the gateway on the Core switch is OK
ip static-route 0.0.0.0/0 gateway 192.168.15.2 metric 1
policy condition StudentVLAN source ip 192.168.10.0 mask 255.255.255.0
policy action toFW2 permanent gateway ip 192.168.15.3
policy rule redirectStud condition StudentVLAN action toFW2
qos apply
policy condition WStudentVLAN source ip 192.168.12.0 mask 255.255.255.0
policy rule redirectWStud condition WStudentVLAN action toFW2
qos apply
policy condition GuestVLAN source ip 192.168.14.0 mask 255.255.255.0
policy action toFW3 permanent gateway ip 192.168.15.4
policy rule redirectGuest condition GuestVLAN action toFW3
qos apply
After I put in the Policy Based Routing (PBR), did a test ping to own gateway is ok, but to other VLAN interface, there is no respond.
However when I do a tracert, I can reach the destination. Had check on the firewall that traffic had goes to the correct FW pointed to and routed had also been added to point back to the Core Switch.
So is it due to the policy based routing blocking Ping functions or I had miss out something which cause the traffic unable to route back correctly? Below is the configuration on the Core Switch and thank for your reply in advanced.
! Stack Manager :
! Chassis :
system name L3-CSW-01
! Configuration:
! VLAN :
vlan 1 enable name "Disabled"
vlan 2 enable name "Management"
vlan 2 port default 1/24
vlan 2 port default 1/25
vlan 2 port default 1/26
vlan 2 port default 1/27
vlan 2 port default 1/28
vlan 2 port default 1/29
vlan 2 port default 1/30
vlan 2 port default 1/31
vlan 2 port default 1/32
vlan 2 port default 1/33
vlan 2 port default 1/34
vlan 2 port default 1/35
vlan 2 port default 1/36
vlan 2 port default 1/45
vlan 2 port default 2/20
vlan 2 port default 2/25
vlan 2 port default 2/26
vlan 2 port default 2/27
vlan 2 port default 2/28
vlan 2 port default 2/29
vlan 2 port default 2/30
vlan 2 port default 2/31
vlan 2 port default 2/32
vlan 2 port default 2/33
vlan 2 port default 2/34
vlan 2 port default 2/35
vlan 2 port default 2/36
vlan 3 enable name "Wireless Management"
vlan 3 port default 1/22
vlan 4 enable name "Student"
vlan 4 port default 1/18
vlan 5 enable name "Staff"
vlan 5 port default 1/19
vlan 5 port default 1/20
vlan 6 enable name "Wireless Student"
vlan 7 enable name "Wireless Staff"
vlan 8 enable name "Guest"
vlan 9 enable name "Firewall"
vlan 9 port default 1/46
vlan 9 port default 1/47
vlan 9 port default 2/47
vlan 10 enable name "Wireless VIP"
! VLAN SL:
! IP :
ip service all
ip interface "Vlan2" address 192.168.8.1 mask 255.255.255.0 vlan 2 ifindex 2
ip interface "Vlan3" address 192.168.9.1 mask 255.255.255.0 vlan 3 ifindex 3
ip interface "Vlan4" address 192.168.10.1 mask 255.255.255.0 vlan 4 ifindex 4
ip interface "Vlan5" address 192.168.11.1 mask 255.255.255.0 vlan 5 ifindex 5
ip interface "Vlan6" address 192.168.12.1 mask 255.255.255.0 vlan 6 ifindex 6
ip interface "Vlan7" address 192.168.13.1 mask 255.255.255.0 vlan 7 ifindex 7
ip interface "Vlan8" address 192.168.14.1 mask 255.255.255.0 vlan 8 ifindex 8
ip interface "Vlan9" address 192.168.15.1 mask 255.255.255.0 vlan 9 ifindex 9
ip interface "vlan10" address 192.168.16.1 mask 255.255.255.0 vlan 10 ifindex 10
! IPX :
! IPMS :
! AAA :
aaa radius-server "192.168.8.9" host 192.168.8.9 key c9ab906dcb630054cf41331b7f81f42c retransmit 3 timeout 2 auth-port 1812 acct-port 1813
aaa radius-server "192.168.8.11" host 192.168.8.11 key c9ab906dcb630054cf41331b7f81f42c retransmit 3 timeout 2 auth-port 1812 acct-port 1813
aaa authentication default "192.168.8.9"
aaa authentication telnet "local"
aaa authentication http "local"
! PARTM :
! AVLAN :
! 802.1x :
! QOS :
qos apply
! Policy manager :
! Session manager :
session prompt default "L3-CSW-01->"
! SNMP :
! RIP :
! OSPF :
! BFD-STD :
! ISIS :
! IPv6 :
! IPSec :
! IP multicast :
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
! Udld :
! Netsec :
! Link Aggregate :
lacp linkagg 1 size 2 admin state enable
lacp linkagg 1 name "L3-CSW-01 P1/1,2/1 to L1-ESW-01 P1/1,1/2"
lacp linkagg 1 actor admin key 1
lacp linkagg 2 size 2 admin state enable
lacp linkagg 2 actor admin key 2
lacp linkagg 3 size 2 admin state enable
lacp linkagg 3 actor admin key 3
lacp linkagg 4 size 2 admin state enable
lacp linkagg 4 actor admin key 4
lacp linkagg 5 size 2 admin state enable
lacp linkagg 5 actor admin key 5
lacp linkagg 6 size 2 admin state enable
lacp linkagg 6 actor admin key 6
lacp linkagg 7 size 2 admin state enable
lacp linkagg 7 actor admin key 7
lacp linkagg 8 size 2 admin state enable
lacp linkagg 8 actor admin key 8
lacp linkagg 9 size 2 admin state enable
lacp linkagg 9 actor admin key 9
lacp linkagg 10 size 2 admin state enable
lacp linkagg 10 actor admin key 10
lacp linkagg 11 size 2 admin state enable
lacp linkagg 11 actor admin key 11
lacp linkagg 12 size 2 admin state enable
lacp linkagg 12 actor admin key 12
lacp linkagg 13 size 2 admin state enable
lacp linkagg 13 actor admin key 13
lacp linkagg 14 size 2 admin state enable
lacp linkagg 14 actor admin key 14
lacp linkagg 15 size 2 admin state enable
lacp linkagg 15 actor admin key 15
lacp linkagg 16 size 2 admin state enable
lacp linkagg 16 actor admin key 16
lacp linkagg 17 size 2 admin state enable
lacp linkagg 17 actor admin key 17
static linkagg 18 size 2 admin state enable
lacp agg 1/1 actor admin key 1
lacp agg 1/2 actor admin key 2
lacp agg 1/3 actor admin key 3
lacp agg 1/4 actor admin key 4
lacp agg 1/5 actor admin key 5
lacp agg 1/6 actor admin key 6
lacp agg 1/7 actor admin key 7
lacp agg 1/8 actor admin key 8
lacp agg 1/9 actor admin key 9
lacp agg 1/10 actor admin key 10
lacp agg 1/11 actor admin key 11
lacp agg 1/12 actor admin key 12
lacp agg 1/13 actor admin key 13
lacp agg 1/14 actor admin key 14
lacp agg 1/15 actor admin key 15
lacp agg 1/16 actor admin key 16
lacp agg 1/17 actor admin key 17
static agg 1/48 agg num 18
lacp agg 2/1 actor admin key 1
lacp agg 2/2 actor admin key 2
lacp agg 2/3 actor admin key 3
lacp agg 2/4 actor admin key 4
lacp agg 2/5 actor admin key 5
lacp agg 2/6 actor admin key 6
lacp agg 2/7 actor admin key 7
lacp agg 2/8 actor admin key 8
lacp agg 2/9 actor admin key 9
lacp agg 2/10 actor admin key 10
lacp agg 2/11 actor admin key 11
lacp agg 2/12 actor admin key 12
lacp agg 2/13 actor admin key 13
lacp agg 2/14 actor admin key 14
lacp agg 2/15 actor admin key 15
lacp agg 2/16 actor admin key 16
lacp agg 2/17 actor admin key 17
static agg 2/48 agg num 18
! Port Mapping :
! VLAN AGG:
! 802.1Q :
vlan 2 802.1q 2/19 "TAG AGGREGATE 2 VLAN 2"
vlan 3 802.1q 2/19 "TAG AGGREGATE 2 VLAN 3"
vlan 4 802.1q 2/19 "TAG AGGREGATE 2 VLAN 4"
vlan 5 802.1q 2/19 "TAG AGGREGATE 2 VLAN 5"
vlan 6 802.1q 2/19 "TAG AGGREGATE 2 VLAN 6"
vlan 7 802.1q 2/19 "TAG AGGREGATE 2 VLAN 7"
vlan 8 802.1q 2/19 "TAG AGGREGATE 2 VLAN 8"
vlan 9 802.1q 2/19 "TAG AGGREGATE 2 VLAN 9"
vlan 10 802.1q 2/19 "TAG AGGREGATE 2 VLAN 10"
vlan 2 802.1q 1 "TAG AGGREGATE 1 VLAN 2"
vlan 3 802.1q 1 "TAG AGGREGATE 1 VLAN 3"
vlan 4 802.1q 1 "TAG AGGREGATE 1 VLAN 4"
vlan 5 802.1q 1 "TAG AGGREGATE 1 VLAN 5"
vlan 6 802.1q 1 "TAG AGGREGATE 1 VLAN 6"
vlan 7 802.1q 1 "TAG AGGREGATE 1 VLAN 7"
vlan 8 802.1q 1 "TAG AGGREGATE 1 VLAN 8"
vlan 9 802.1q 1 "TAG AGGREGATE 1 VLAN 9"
vlan 10 802.1q 1 "TAG AGGREGATE 1 VLAN 10"
vlan 2 802.1q 2 "TAG AGGREGATE 2 VLAN 2"
vlan 3 802.1q 2 "TAG AGGREGATE 2 VLAN 3"
vlan 4 802.1q 2 "TAG AGGREGATE 2 VLAN 4"
vlan 5 802.1q 2 "TAG AGGREGATE 2 VLAN 5"
vlan 6 802.1q 2 "TAG AGGREGATE 2 VLAN 6"
vlan 7 802.1q 2 "TAG AGGREGATE 2 VLAN 7"
vlan 8 802.1q 2 "TAG AGGREGATE 2 VLAN 8"
vlan 9 802.1q 2 "TAG AGGREGATE 2 VLAN 9"
vlan 10 802.1q 2 "TAG AGGREGATE 2 VLAN 10"
vlan 2 802.1q 3 "TAG AGGREGATE 3 VLAN 2"
vlan 3 802.1q 3 "TAG AGGREGATE 3 VLAN 3"
vlan 4 802.1q 3 "TAG AGGREGATE 3 VLAN 4"
vlan 5 802.1q 3 "TAG AGGREGATE 3 VLAN 5"
vlan 6 802.1q 3 "TAG AGGREGATE 3 VLAN 6"
vlan 7 802.1q 3 "TAG AGGREGATE 3 VLAN 7"
vlan 8 802.1q 3 "TAG AGGREGATE 3 VLAN 8"
vlan 9 802.1q 3 "TAG AGGREGATE 3 VLAN 9"
vlan 10 802.1q 3 "TAG AGGREGATE 3 VLAN 10"
vlan 2 802.1q 4 "TAG AGGREGATE 4 VLAN 2"
vlan 3 802.1q 4 "TAG AGGREGATE 4 VLAN 4"
vlan 4 802.1q 4 "TAG AGGREGATE 4 VLAN 4"
vlan 5 802.1q 4 "TAG AGGREGATE 4 VLAN 5"
vlan 6 802.1q 4 "TAG AGGREGATE 4 VLAN 6"
vlan 7 802.1q 4 "TAG AGGREGATE 4 VLAN 7"
vlan 8 802.1q 4 "TAG AGGREGATE 4 VLAN 8"
vlan 9 802.1q 4 "TAG AGGREGATE 4 VLAN 9"
vlan 10 802.1q 4 "TAG AGGREGATE 4 VLAN 10"
vlan 2 802.1q 5 "TAG AGGREGATE 5 VLAN 2"
vlan 3 802.1q 5 "TAG AGGREGATE 5 VLAN 3"
vlan 4 802.1q 5 "TAG AGGREGATE 5 VLAN 4"
vlan 5 802.1q 5 "TAG AGGREGATE 5 VLAN 5"
vlan 6 802.1q 5 "TAG AGGREGATE 5 VLAN 6"
vlan 7 802.1q 5 "TAG AGGREGATE 5 VLAN 7"
vlan 8 802.1q 5 "TAG AGGREGATE 5 VLAN 8"
vlan 9 802.1q 5 "TAG AGGREGATE 5 VLAN 9"
vlan 10 802.1q 5 "TAG AGGREGATE 5 VLAN 10"
vlan 2 802.1q 6 "TAG AGGREGATE 6 VLAN 2"
vlan 3 802.1q 6 "TAG AGGREGATE 6 VLAN 3"
vlan 4 802.1q 6 "TAG AGGREGATE 6 VLAN 4"
vlan 5 802.1q 6 "TAG AGGREGATE 6 VLAN 5"
vlan 6 802.1q 6 "TAG AGGREGATE 6 VLAN 6"
vlan 7 802.1q 6 "TAG AGGREGATE 6 VLAN 7"
vlan 8 802.1q 6 "TAG AGGREGATE 6 VLAN 8"
vlan 9 802.1q 6 "TAG AGGREGATE 6 VLAN 9"
vlan 10 802.1q 6 "TAG AGGREGATE 6 VLAN 10"
vlan 2 802.1q 7 "TAG AGGREGATE 7 VLAN 2"
vlan 3 802.1q 7 "TAG AGGREGATE 7 VLAN 3"
vlan 4 802.1q 7 "TAG AGGREGATE 7 VLAN 4"
vlan 5 802.1q 7 "TAG AGGREGATE 7 VLAN 5"
vlan 6 802.1q 7 "TAG AGGREGATE 7 VLAN 6"
vlan 7 802.1q 7 "TAG AGGREGATE 7 VLAN 7"
vlan 8 802.1q 7 "TAG AGGREGATE 7 VLAN 8"
vlan 9 802.1q 7 "TAG AGGREGATE 7 VLAN 9"
vlan 10 802.1q 7 "TAG AGGREGATE 7 VLAN 10"
vlan 2 802.1q 8 "TAG AGGREGATE 8 VLAN 2"
vlan 3 802.1q 8 "TAG AGGREGATE 8 VLAN 3"
vlan 4 802.1q 8 "TAG AGGREGATE 8 VLAN 4"
vlan 5 802.1q 8 "TAG AGGREGATE 8 VLAN 5"
vlan 6 802.1q 8 "TAG AGGREGATE 8 VLAN 6"
vlan 7 802.1q 8 "TAG AGGREGATE 8 VLAN 7"
vlan 8 802.1q 8 "TAG AGGREGATE 8 VLAN 8"
vlan 9 802.1q 8 "TAG AGGREGATE 8 VLAN 9"
vlan 10 802.1q 8 "TAG AGGREGATE 8 VLAN 10"
vlan 2 802.1q 9 "TAG AGGREGATE 9 VLAN 2"
vlan 3 802.1q 9 "TAG AGGREGATE 9 VLAN 3"
vlan 4 802.1q 9 "TAG AGGREGATE 9 VLAN 4"
vlan 5 802.1q 9 "TAG AGGREGATE 9 VLAN 5"
vlan 6 802.1q 9 "TAG AGGREGATE 9 VLAN 6"
vlan 7 802.1q 9 "TAG AGGREGATE 9 VLAN 7"
vlan 8 802.1q 9 "TAG AGGREGATE 9 VLAN 8"
vlan 9 802.1q 9 "TAG AGGREGATE 9 VLAN 9"
vlan 10 802.1q 9 "TAG AGGREGATE 9 VLAN 10"
vlan 2 802.1q 10 "TAG AGGREGATE 10 VLAN 2"
vlan 3 802.1q 10 "TAG AGGREGATE 10 VLAN 3"
vlan 4 802.1q 10 "TAG AGGREGATE 10 VLAN 4"
vlan 5 802.1q 10 "TAG AGGREGATE 10 VLAN 5"
vlan 6 802.1q 10 "TAG AGGREGATE 10 VLAN 6"
vlan 7 802.1q 10 "TAG AGGREGATE 10 VLAN 7"
vlan 8 802.1q 10 "TAG AGGREGATE 10 VLAN 8"
vlan 9 802.1q 10 "TAG AGGREGATE 10 VLAN 9"
vlan 10 802.1q 10 "TAG AGGREGATE 10 VLAN 10"
vlan 2 802.1q 11 "TAG AGGREGATE 11 VLAN 2"
vlan 3 802.1q 11 "TAG AGGREGATE 11 VLAN 3"
vlan 4 802.1q 11 "TAG AGGREGATE 11 VLAN 4"
vlan 5 802.1q 11 "TAG AGGREGATE 11 VLAN 5"
vlan 6 802.1q 11 "TAG AGGREGATE 11 VLAN 6"
vlan 7 802.1q 11 "TAG AGGREGATE 11 VLAN 7"
vlan 8 802.1q 11 "TAG AGGREGATE 11 VLAN 8"
vlan 9 802.1q 11 "TAG AGGREGATE 11 VLAN 9"
vlan 10 802.1q 11 "TAG AGGREGATE 11 VLAN 10"
vlan 2 802.1q 12 "TAG AGGREGATE 12 VLAN 2"
vlan 3 802.1q 12 "TAG AGGREGATE 12 VLAN 3"
vlan 4 802.1q 12 "TAG AGGREGATE 12 VLAN 4"
vlan 5 802.1q 12 "TAG AGGREGATE 12 VLAN 5"
vlan 6 802.1q 12 "TAG AGGREGATE 12 VLAN 6"
vlan 7 802.1q 12 "TAG AGGREGATE 12 VLAN 7"
vlan 8 802.1q 12 "TAG AGGREGATE 12 VLAN 8"
vlan 9 802.1q 12 "TAG AGGREGATE 12 VLAN 9"
vlan 10 802.1q 12 "TAG AGGREGATE 12 VLAN 10"
vlan 2 802.1q 13 "TAG AGGREGATE 13 VLAN 2"
vlan 3 802.1q 13 "TAG AGGREGATE 13 VLAN 3"
vlan 4 802.1q 13 "TAG AGGREGATE 13 VLAN 4"
vlan 5 802.1q 13 "TAG AGGREGATE 13 VLAN 5"
vlan 6 802.1q 13 "TAG AGGREGATE 13 VLAN 6"
vlan 7 802.1q 13 "TAG AGGREGATE 13 VLAN 7"
vlan 8 802.1q 13 "TAG AGGREGATE 13 VLAN 8"
vlan 9 802.1q 13 "TAG AGGREGATE 13 VLAN 9"
vlan 10 802.1q 13 "TAG AGGREGATE 13 VLAN 10"
vlan 2 802.1q 14 "TAG AGGREGATE 14 VLAN 2"
vlan 3 802.1q 14 "TAG AGGREGATE 14 VLAN 3"
vlan 4 802.1q 14 "TAG AGGREGATE 14 VLAN 4"
vlan 5 802.1q 14 "TAG AGGREGATE 14 VLAN 5"
vlan 6 802.1q 14 "TAG AGGREGATE 14 VLAN 6"
vlan 7 802.1q 14 "TAG AGGREGATE 14 VLAN 7"
vlan 8 802.1q 14 "TAG AGGREGATE 14 VLAN 8"
vlan 9 802.1q 14 "TAG AGGREGATE 14 VLAN 9"
vlan 10 802.1q 14 "TAG AGGREGATE 14 VLAN 10"
vlan 2 802.1q 15 "TAG AGGREGATE 15 VLAN 2"
vlan 3 802.1q 15 "TAG AGGREGATE 15 VLAN 3"
vlan 4 802.1q 15 "TAG AGGREGATE 15 VLAN 4"
vlan 5 802.1q 15 "TAG AGGREGATE 15 VLAN 5"
vlan 6 802.1q 15 "TAG AGGREGATE 15 VLAN 6"
vlan 7 802.1q 15 "TAG AGGREGATE 15 VLAN 7"
vlan 8 802.1q 15 "TAG AGGREGATE 15 VLAN 8"
vlan 9 802.1q 15 "TAG AGGREGATE 15 VLAN 9"
vlan 10 802.1q 15 "TAG AGGREGATE 15 VLAN 10"
vlan 2 802.1q 16 "TAG AGGREGATE 16 VLAN 2"
vlan 3 802.1q 16 "TAG AGGREGATE 16 VLAN 3"
vlan 4 802.1q 16 "TAG AGGREGATE 16 VLAN 4"
vlan 5 802.1q 16 "TAG AGGREGATE 16 VLAN 5"
vlan 6 802.1q 16 "TAG AGGREGATE 16 VLAN 6"
vlan 7 802.1q 16 "TAG AGGREGATE 16 VLAN 7"
vlan 8 802.1q 16 "TAG AGGREGATE 16 VLAN 8"
vlan 9 802.1q 16 "TAG AGGREGATE 16 VLAN 9"
vlan 10 802.1q 16 "TAG AGGREGATE 16 VLAN 10"
vlan 2 802.1q 17 "TAG AGGREGATE 17 VLAN 2"
vlan 3 802.1q 17 "TAG AGGREGATE 17 VLAN 3"
vlan 4 802.1q 17 "TAG AGGREGATE 17 VLAN 4"
vlan 5 802.1q 17 "TAG AGGREGATE 17 VLAN 5"
vlan 6 802.1q 17 "TAG AGGREGATE 17 VLAN 6"
vlan 7 802.1q 17 "TAG AGGREGATE 17 VLAN 7"
vlan 8 802.1q 17 "TAG AGGREGATE 17 VLAN 8"
vlan 9 802.1q 17 "TAG AGGREGATE 17 VLAN 9"
vlan 10 802.1q 17 "TAG AGGREGATE 17 VLAN 10"
vlan 3 802.1q 18 "TAG AGGREGATE 18 VLAN 3"
vlan 6 802.1q 18 "TAG AGGREGATE 18 VLAN 6"
vlan 7 802.1q 18 "TAG AGGREGATE 18 VLAN 7"
vlan 8 802.1q 18 "TAG AGGREGATE 18 VLAN 8"
vlan 10 802.1q 18 "TAG AGGREGATE 18 VLAN 10"
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
ip helper address 192.168.8.12
! Server load balance :
! System service :
swlog console level info
! SSH :
! VRRP :
! Web :
! AMAP :
! LLDP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! Ethernet-OAM :
! EFM-OAM :
! ERP :
! SAA :
! DHCP Server :
Thank you very much for your assistance.
Policy Based Routing Issue
cedric1
Re: Policy Based Routing Issue
Post by cedric1 »
so ping from
192.168.14.0 to ip 192.168.15.4 is working or not ?
if can give source/destination of what is working and not
Take care on reply packet , as best is to do source nat on firewall, so you are sure packet coming back enter same firewall.
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
