Hi guys,
Any of you have an idea where in the hell is the TG guide??? All I can find the mobility one...where did they put it now??
TG guide for 6.x
- cavagnaro
TG guide for 6.x
Re: TG guide for 6.x
I really think is not yet released!! Just for OTUC ( TG rel 5.1 ed7 ). For rel 6.x there is only for mobility features.
- cavagnaro
sucks as MyIC way to get logs has changed and can't find out how...seems also that standard pcmm.cfg file for Abers/Gaelic doesn't work neither...
ALU my ALU.... :S
ALU my ALU.... :S
Hi Cav,
i find this may be its the file what you are looking for, .......i hope it helps
ACSE OmniPCX Enterprise Business R9/10/11
ACSE ICS 8400 R6
ACSE OpenTouch R1/R2
ACSE ICS 8400 R6
- cavagnaro
nice, thanks! will try it
