4008 Sip Firmware
davcham9
4008 Sip Firmware
Post by davcham9 »
Good Morning All
I have recently purchased a second hand ip touch 4008 EE with firmware version NOE 3.91.60.
I would like to change this to the sip firmware so I can connect it to my 3CX box using sip.
Is it possible for someone to pass the firmware to me with instructions on how to download it using a tftp on a windows machine( I don't have OmniPCX to be able to set the phone up normally).
Thank you in advanced.
alex
Re: 4008 Sip Firmware
Post by alex »
A lot of good reading is here
4XX8EE Phones with Asterisk
davcham9
Post by davcham9 »
Thanks for that. I have read that already but unless I can get the sip firmware I am pretty much stuck.
alex
Post by alex »
On the 2nd page of the above-mentioned discussion you will find two links - one for the docs, second - for the binaries.
juliehimaya
Post by juliehimaya »
My iptouch 4008 is having firmware Version NOE 3.91.60
I have a problem on my ip touch 4008. When i trying to go in to the SOFT INFOS, Run mode display NOE. I am trying to change from NOE to Sip, but no SIP options.
Anybody have an idea how could I change the Run Mode for NOE to SIP?
Highly appreciated thanks.
Return to “Alcatel-Lucent Series 8&9”
