Hunt Group composed by SIP devices
Sidney
Post by Sidney »
Him
Someone here knows if there is any way to include SIP devices in a HUNT GROUP ? It´s not allowed by configuration.
The scenario that I need is to call one of several SIP devices that are configured at OXE system when a call comes in through a DID number.
System software = I1.605.21
Thanks in advance
enio.eltz
Re: Hunt Group composed by SIP devices
Post by enio.eltz »
Have you tried to set the extensions as SIP extension?
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Sidney
Post by Sidney »
Hi, Enio
Thanks for you reply.
Yes .. Configuring as SIP extensions, it´s really possible to include in a Hunt Group.
However, we have problems with DTMF sending (that we want to use in order to give some special treatment through an application that we intend to develop).
If configured as SIP devices, we do not problems with DTMF. But it´s not possible to put into a hunt group.
enio.eltz
Post by enio.eltz »
What kind of problems with DTMF tones?
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Konstantinos.E
Post by Konstantinos.E »
hello
hunting groups cannot be parrallel ringing in ua and voip devices.. can be made only with mla groups.
Although you can make a virtual z and supervise it with ringing in one of keys on the device.
to sent DTMF tones you have to make a prefix to declare it to the system.
cheers!
Return to “Groups”
