Low speech in analog CO trunks
lobhugo
Post by lobhugo »
Can the speech quality in NDDI type analog trunk card be boosted.I am facing a problem of very poor speech quality.
Tks
patmul39
Poor speech quality
Post by patmul39 »
First check Trunk COS in the created trunk. Then go to External Services / Trunk COS (same as the trunk cos in the trunk group) and modify the Line Type (set to Long Line as this will increase line gain). You must reset the NDDI board afterwards. Play around with the Long Line options.
Check line quality first. Connect analog set on th line (without PBX) and check audio. If you have bad line PBX cannot improve quality.
If with direct connection OK - Specific telephone services - Adjust audio gain=yes. You will have possibility adjust level in handset with key "+", "-".
huni
Post by huni »
sometimes linereversing also works !!!1
Return to “GENERAL”
