I've a problem with a user in my OXE.
it's currently deleted of my base with cuser but the numan is associate with a nulog.(command tradna ____)
My question : which table in the OXE associate the numan and the nulog??
=> sorry for my english, I'm french...
Impossible to delete a user
I supose you delete the number on poste, phoneb, tabtrad and keyboard tables.
The nulog/numan are in memory, so you must to a reset or if you want, give me the remote access number and i will remove it from memory
stseya
Eliott_DUP
Re: Impossible to delete a user
POSTEsadim wrote:I supose you delete the number on poste, phoneb, tabtrad and keyboard tables.
PHONEB
TABTRAD
KEYBOARD
You should also check:
TABRAL
RALBIT
REPERT
PIN
INTERPH
TABALARM
TAB_AGENT
WBLISTAG
CORDLESS
...and so on...
Carefully if editing the database by hand!
PS: You should to a checkdb and a chek and repair using "multitool CHECK REPAIR" (in /usr3/mao) after your changes.
To to a reboot is necessary if you're not using listrad to modify the memory. (And it's more easy)
Sometimes it gives an idea to use the "mgr -line".
Choose your object and the memorize the ID e.g. -> 890052:S0 Bus
Then check the file /usr2/fab/obj2tbl.ref for object 890052:
Object_Identifier:Object_Name:#define:Table_Name:Access_Rights
890052:S0_Bus:OBJ_S0_BUS:T_ACCES:READ_WRITE
890052:S0_Bus:OBJ_S0_BUS:T_POSTE:READ_WRITE
890052:S0_Bus:OBJ_S0_BUS:T_S0BUS:READ_WRITE
Following this, you have to check the tables
ACCES
POSTE
and
S0BUS
if you change a S0 set.
(Revese with tbl2obj.ref)
- tot3nkopf
To know exactly what tables to search in and delete from you can create a user in your OXE with the same characteristics as the problematic one and then activate a trace:
srvtrace
traced &
then delete user and see what trace shows you and do the same with cuser for the problem user.
Hope that helps.
srvtrace
traced &
Hope that helps.
stseya
Eliott_DUP
