ERASING AND RELOADING OF GA3
almatel
Post by almatel »
Dear all,
Does anyone know how to erase and reload the GA3 board? Because I tried to follow the steps was described in Alcatel doc. (Please See the attach Alcatel doc.) , But it doesn’t work, beside I got confused about first step was described in the installation process about inserting the GA3 board in to into the CPU position of the rack (0 for GD3/GA3, 6, 10 or 20 for the INTIP3).!?!?!?!?.
How come is that and the GA3 doesn’t power on itself (not like GD3 or previous GD/GA boards).
Please advice
sera544
Re: ERASING AND RELOADING OF GA3
Post by sera544 »
Means..if u want format GD3 or GA3 , u have to insert in slot no 0..connect corss cable and config cable to laptop or pc then power on...rest of the procedure is same as its old...
ACSE Business R.9.x
almatel
Post by almatel »
How come is that and the GA3 doesn’t power on itself(not like GD3 or previous GD/GA boards).
Return to “Software Loading”
