How to see people who have called you?
wozzzzza
Post by wozzzzza »
i have an alcatel lucent system with 4039 handset. when someone calls i have caller ID that shows their number, but after the call it disappears and i have no idea how to get it back to see it. can it be done? if so how? i cant work it out.
tincho.rn
Re: How to see people who have called you?
Post by tincho.rn »
Hi. You will need My Instant Communicator. Regards.
wozzzzza
Post by wozzzzza »
is that easy to get and put on?
swinstation
Post by swinstation »
hi
try last caller callback prefix,maybe it helps .
wwe
Post by wwe »
As far I know there is no built-in call list. But if you know you need to recall your callee later just program a programmable key "redial memory" and press it while the call is active. You can call the number later by pressing the key again. This work for both directions incoming and outgoing calls.
Return to “Alcatel-Lucent Series 8&9”
