Cisco IP Phones Over a 6850
salvador_cab
Post by salvador_cab »
Does anyone know if it is possible to connect Cisco IP Phones on a 6850?? I never done that and I knew that Cisco has some propietary protocols that don´t allow us to use different switch platform than Cisco.
Re: Cisco IP Phones Over a 6850
I haven't tested cisco phones with Alcatel switches until now. But it should work. Alcatel don't block other protocols. QoS will not work automaticly. There you have to create your own policy - or make the phone-ports trusted if the phones sent DSCP.
Check if your phones support poe with 802.3af. You have to switch-on lanpower at the switch.
Try it.
regards Silvio
TelluR
Post by TelluR »
All Cisco IP Phones with PoE work in these Switch!!
btsforklift
Post by btsforklift »
TelluR wrote:All Cisco IP Phones with PoE work in these Switch!!
And just in case...this is what you need if they don't. Works well for us under similar circumstances:
http://www.panoptictechnology.com/netwo ... -adapters/
