Outgoing fax problem
airwolf
Post by airwolf »
Hi All
I am having problems dialing out from my fax server
The server sends the sip invite to the OXE but the call fails and the error on the fax is an 804
See attached for sip trace
Please help
Chris
OXE_4400
Re: Outgoing fax problem
Post by OXE_4400 »
It looks that OXE require authentification. Try to switch off it all.
airwolf
Post by airwolf »
My OXE is set for sip digest = none on both proxy and external gateway. is there somewhere else for authentication that needs disabling?
airwolf
Post by airwolf »
Thanks for your help, for some reason after we had our power off all weekend the fax server is now able to send out, even though I had already completely re booted everything!! ah well good old Alcatel
Return to “OmniTouch 8450 Fax Software”
