Pilot delete failed
xister
Pilot delete failed
Post by xister »
Hello everybody,
i want delete a very old pilot in our OmniVista 4670.
But i get the following error:
[8:52:33 AM] > Delete \Prodefacto\Applications::1\CCD::1\Pilot::181
                    Pilot Directory Number : Used for direct call
How i get the unused pilot deleted?
greetings from germany
Do you have CCs software? Where you can see f.e. status (opened, blocked...)
xister
Post by xister »
Yes, we have the CCS Software.
The pilot status is "blocked" and there´s no call rule defined.
CR0673
Post by CR0673 »
Hi xister,
your pilot is assigned as "Pilot direct call" in a Processing Group. That's why you can't delete it.
bye
Return to “Configuration”
