ICS server Upgrading's issue
agiftel
Hi folk, i am facing this issue. I am tring to upgrade ICS server from rel 6.1.000.101b to 6.1.000.102a. The issue is regarding root partion. The initial check fails because lack of HD space. Installation/upgrade requires al least 6 Gb of free HD. I get 5.6 Gb. Do you know if there is a workaround to solve it? I CAN'T change Server or re-istall all from scratch.
Any idea??
Thnaks
Any idea??
Thnaks
agiftel
rogern
Re: ICS server Upgrading's issue
I didn't find any hotfix on the BPWS, except the mobility hotfix for the 103 version...
banfield
Log in as root@uc logs# df
There you have log files. I had 1,4 gb.
Stop icsd
UC/logs
Use
Find . –name ”*.log.? –delete
Stop icsd
UC/logs
Use
4980forever
Hi guys,
the mobility patch from ICS 6.1.000.103b is nit the right one. You must search this Hotfix: TC1369en-Ed01_HotFixTT16221.pdf
Or use this one
Or use this one
agiftel
Hi, I am facing again same problem. I would like to upgrade to last ICS rel, ( 6.1.000.103c ) but update fails due lack of HD space.
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vg01-rootvol
15G 9.9G 3.9G 72% /
/dev/mapper/vg01-vmsvol
113G 2.3G 105G 3% /var/vms
/dev/mapper/vg01-data2vol
2.0G 68M 1.8G 4% /data/data2
/dev/mapper/vg01-data5vol
2.0G 68M 1.8G 4% /data/data5
/dev/mapper/vg01-data3vol
2.0G 68M 1.8G 4% /data/data3
/dev/mapper/vg01-logsvol
2.0G 1.4G 464M 76% /logs
/dev/mapper/vg01-data6vol
2.0G 68M 1.8G 4% /data/data6
/dev/mapper/vg01-data1vol
3.9G 137M 3.6G 4% /data/data1
/dev/mapper/vg01-data4vol
2.0G 68M 1.8G 4% /data/data4
/dev/sda1 99M 12M 82M 13% /boot
tmpfs 2.5G 0 2.5G 0% /dev/shm
As you can see / partitions has 3.9 Gb free but are required at least 6 Gb. I checked about OFS issue but I had already applied the hotfix TC1369en-Ed01_HotFixTT16221.pdf.
Any suggestions?
15G 9.9G 3.9G 72% /
Any suggestions?
Well 6Gb are needed...try deleting something or do a backup, save it and do a clean install
agiftel
Yes I know, fresh installation was the last solution.. I already tried to deleate something but reach 6Gb of free space is a hard work.
Thanks anyway.
Thanks anyway.
