IP doorcam
krzysioD
IP doorcam
Post by krzysioD »
basically i've got a bunch of cheap ip-cameras, and some 4068 on site.
what I need to see captures from ip cameras on 4068?
at least one server for XML server? What version do i need?
at least license for ipdoorcam app? do i need extra server for that?
OXE R9.1 if it matters. the latest patch .22
smileyman
Post by smileyman »
Hi krzysioD,
we have 2 doorcams on 10 4068-Extensions. This is running on the Alcatel-XML-Server.
You need a XML-Licence and a Doorcam-Application.
In my opinion the Alcatel-Doorcam-Application need special Alcatel-Cams. (can somebody confirm this?)
We have this Doorcam-Application (in the PDF are some screenshots - let me know if you need more informationes) with an normal IP-Cam.
Best regards
smileyman
krzysioD
Post by krzysioD »
Sorry, i don't speak German :(.
So, it's:
one server: XML + Doorcam, license for XML (on server, not OXE) and license for Doorcam.
Thanks.
smileyman
Post by smileyman »
No problem ;-)
Yes we have the Alcatel XML-Server on a separate Hardware. The Application runs on the XML-Server.
You need on OXE-Side:
User x TELEPHONY WEB SERVICES - License
User x IP TOUCH XML BASIC SERVICES - License
1 x WEB SERVICES R6.0 - License
1 x OTUC/XML/WEB-SERVICE INTERACTION FRAMEWORK - License
1 x RED HART ENTERPRISE LINUX ENTERPRISE R5.0 - License
Then you need the Doorcam-Application with license, installed on the XML-Server.
Best regards
smilemyan
Or you can build your own application. I guess that the IP Cameras will need to export the video image to a JPEG image, and then the XML application will show this image...not hard to do, I have done an application like this a couple of years ago
krzysioD
Post by krzysioD »
for ALU XML?
Yup :)
Return to “XML Presentation Server & TAPI Server”
