We are using ipdomain for each sites with g729 compression over WAN links.
The problem is for fax machine on SLI card.
The call isn't connected directly to local PSTN but throught WAN then E1 link on the main site.
So the call is considered as an extra domain call and compressed.
Using the E1's main site the fax cannot connect and return error :
"END TO END INFO TRANSMISSION IMPOSSIBLE"
If we force to use local PSTN (we have backup link on site) the fax works fine.
Using an other backup link on an other site same issue as main site.
So my first guess is the codec.
My problem is that i need to use g729 codec over WAN for phones and i'm searching how to make this configuration.
I look on fax/modem transparency but it seems that we must configure the extra domain to no compression ...
If you have any tricks !
Thanks for reading
