MAO Data Recovery on Faulty R5.0Ux Hard Disk
kzaman69
Post by kzaman69 »
Dear Friends,
I would like to know is there any way we can recover MAO data from a faulty HD of R5.0Ux in case we don't have backup data.
From the forum, there are descriptions on recovering MAO data for Linux but unfortunately not on UNIX.
Appreciate the assistance.
Kamaruzaman
Konstantinos.E
Post by Konstantinos.E »
hi...
R studio is a good software to try to recover data....all you need is the directory /usr4/backup/IMMED and usr4/backup/OPS
if R studio doesnt see your hd then you can not do much about it.....although i had a similar case with crashed hd and i recoverd data i need it by putting the hd in the freezer....:P
alex
Post by alex »
kzaman69 wrote:Dear Friends,
Kamaruzaman
Depends on the type of HD fault.
Anyway, try to load this CPU with BOOTP from BOOTNET package, proceed to "specific installation", mount HD (or any partition you need) and ftp files from /usr4/BACKUP (if this directory is readable) to PC.
kzaman69
Post by kzaman69 »
Thank you dear friends. Appreciate your reply
Commens to first answer - you need to repair /usr4/BACKUP/DAY (or DAY-?, WEEK-? or MONTH-?).
IMMED (99%) will empty. OPS - not intresting. OPS files present in database backup.
Konstantinos.E
yes i agree with vad... but it wiil be strange not someone take imiddiate back ever...
and also is good to have the ops files for backed up for any case.. in my opinion..
Return to “Software Loading”
