Is it possible in OXE the feature of Voicemail Transfer? If the guest doesnt like his/her room and ask to change it the messages saved should be transfered to the new room/extension number.
Thanks,
Jonnel
Voicemail Transfer
- jonnel_ponesto
- jonnel_ponesto
Re: Voicemail Transfer
Good topic that related to the Voicemail transfer.GPIN is a Global Pin.you can save voice mail in amp format and after that you can move voice mail outside.where you can go voice mail can save on mobile .amp format.the size of the file is small but the voice bandwith is not good with .amp file.
