IPDesktop softphone for windows 7
Rezakaa
Post by Rezakaa »
Someone knows when that will IPDesktop softphone compatible with Windows 7, or some way to make it work?. I need this urgent.
Regards.
Konstantinos.E
Post by Konstantinos.E »
hi
i dont know but a good solution is to install xinxp on vmware and work from there :P
alex
Post by alex »
Latest 9.1.2.6 version officially supports Windows 7.
banfield
Re: IPDesktop softphone for windows 7
Post by banfield »
But 64 bits is not supported? I tried to install it on 64 bits. Installation works but functionality in the program breaks.
No, read the documentation about the software
banfield
Post by banfield »
cavagnaro wrote:No, read the documentation about the software
Yes I have read the Installation admin guide ,IP Desktop Softphone 9.1.2.8 release note,IPDSPForFlexOffice,TC1320en and USER_GUIDE.
Were is 32 bit ore 64 bit specefied?
when we talk about OS it is assumed, unless other is specified, that we talk about 32bit, so if 64 is not listed then no support. Or, as usual my friend, you can go and kick off ALU door ;)
Return to “Ip Desktop Softphone”
