Does anyone have 8450 in HA mode?
For ex.: first (primary) 8450 server has host name faxserver1 and IP 192.168.1.1, second (backup) 8450 server has host name faxserver2 and IP 192.168.1.2.
How to access current primary 8450 server from WEB access, from Outllook or Lotus server in universal way not depending which one 8450 server active at the moment? Can't find any info in docs.
Thanks in advance
8450 in High Availability (HA) mode
Problem closed ( I hope
Note: Your DNS should provide an entry that points to the shared IP address of the fax server
cluster. This IP address acts like a virtual address that is always associated to the primary node (it
can be sometimes the first node, sometimes the second node, depending on their status within
the cluster).
Note: For additional references, you may need to consult the following websites:
• http://www.drbd.org/
• http://www.redhat.com/cluster_suite/
the cluster).
Re: 8450 in High Availability (HA) mode
Question again.
Does anybody has 8450 in HA?
It seams that I am alone with 8450 HA. Got new problem that Cluster manager doesn't respond to clustat or clusvcadm commands. I would be grateful for any help.
