ICS 6.1 Installation error
prasad0777
Post by prasad0777 »
hi ...
I tried to install ICS 6.1 server. My checksystemlinux.sh file says everything ok. but After selecting Primary server the installation stops right there. it says to go to log file and read the error. So I read the error it says "after you change FQDN you must restart the server." But I did not change the FQDN. Anyway when I restart the server it says the same thing. What should I do about this.
Thanks,
Prasad
Primary Server? So you have multiple servers?
prasad0777
It was DNS error. I have fix it. Remember you need to create Reverse look up zone for DNS to work. Thanks Cavagnaro for your interest.
H-MAN
Post by H-MAN »
When running the checksystemlinux the error was not mentioned?
H-MAN
Post by H-MAN »
When running the checksystemlinux.sh the error was not mentioned?
prasad0777
yes ... it was not mentioned in checksystemlinux. acctually I was able to pass the checksystemlinux without any error.
forban
Post by forban »
Hello Prasad, would you mind pasting here the content of the DNS tests section of /var/log/OmniTouchUC/InstallLog/checkSystemLinux.log and the exact ICS release/patch level please ?
Thank you very much.
