Hardware Profile Not OK During running Bootp
spring
Post by spring »
I want to creating a software release 5.1 in my OXO system. During running Lola application, it detect my OXO CPU and show connected. But a warning message "Hardware profile not OK" is displayed and then disconnect the connection.
et
Post by et »
Did you change the dip-switch on the CPU board before start LoLa? You can found about this issue in help of LoLa. Good luck!
spring
Post by spring »
Already done DIP Switch 3 set to off.
et
Post by et »
What type of CPU you have? Only CPU-3 can work with R5 without hard disk. All other CPUs need hard disk. Hard disk can be placed on daughterboards: XMEM or VoIP. On CPU you must have 64 MB memory or more.
spring
Post by spring »
Sorry. It's my fault. I am using CPU3 but I select the options Internet and VoIP during Lola process.
et
Post by et »
VoIP you can use, but Internet - no.
Return to “MAIN”
