ICS and OXE Rel 8.0.1 Spatial Redundancy problem
sedel_m
Post by sedel_m »
i got a problem with a Rel 8.0.1 OXE and OTUC 5.1 in spatial Reduandancy enviroment . In Rel 9.1 i can configure the external Voicemail as it shoult :
+-Review/Modify: External Voice Mail-------------------------------------------+
| Node Number (reserved) : 1 |
| Instance (reserved) : 1 |
| Voice Mail Dir.No. : 910 |
| Directory Name : UM |
| Connection COS : 0 |
| Public Network COS : 2 |
| Entity Number : 1 |
| Cost Center ID : 255 |
| Charging COS + Justified |
| URL UserName : 910 |
| URL Domain : pnrtoxem |
| SIP Authentication : --------------------------------------- |
| SIP Passwd : ---------- |
| Confirm : ---------- |
| Register On Line Number : -------- |
| Register URL (Username) : --------------------------------------- |
| Register URL (Domain) : --------------------------------------- |
the URL Domain = Node Name so spatial redundancy and Voicemail is working .
But i got a OXE Rel. 8.0.1 and if i do the same
creating external Voicemail :
| Node Number (reserved) : 101 |
| Voice Mail Dir.No. : 9011 |
| Directory Name : 9011 |
| Entity Number : 0 |
| URL UserName : 9011 |
| Remote SIP domain + False |
| URL Domain : cslwv |
and when i look again in the voicemail number it has changed the entry back to IP Adress
| Entity Number : 0 |
| URL Domain : 10.172.67.10 |
and spatial redundancy is not working
Any Ideas ?
Steffen
I think that it is a feature of R9, do upgrade
sedel_m
Post by sedel_m »
a kolleque found it yesterday , you can change the URL Domain name under SIP -- SIP Dictionary to the right DNS Node Name and then it works
Steffen
