Setting up voicemail on OmniPCX v5
WAH
Post by WAH »
New user - just registered today... Hoping I've posted this question in the correct forum.
Question concerns how to set up voicemail for OmniPCX (medium) using OMC510/14.1c, ie a step-by-step guide for a computer-literate user, though not a telephony engineer.
Specifically, we're a SOHO setup in Ireland with a single ISDN line, an Advanced Reflexes & Premium Reflexes plus four DECTmobile 200; hunting groups allow the business no. to ring on some sets & the home no. to ring on some (of which two are exclusively "home", the others shared). I had to remove the DECT unit from the Premium Reflexes set, so that it's now on a regular RJ11; it had voicemail & forward-to-mobile set up but lost these during the conversion from DECT (see para 2...). Further, in attempting to resolve, I managed to lose the mailbox function on the "home" Advanced set.
Assuming that's not TMI, can I elicit some help in starting from scratch to rebuild voicemail & forward-to-mobile on both the home & business phones?
Thanks in advance,
Walter
tincho.rn
Post by tincho.rn »
Hi. I moved your post. Is OXO (OmniPCX Office) and not OXE because you are talking about OMC (configuration tool for OXO). Regards.
WAH
Post by WAH »
Thanks for placing correctly - it was a stab in the dark guessing correct forum. Now I know what OXO is... WAH
PuGZopf
Post by PuGZopf »
HEllo WAH,
it would be recommend to get the latest OMC Version for your country. Today OMC R711 57.1c is the newest.
You go to the subscriber list and the detailed view from the phone ( wich type is not important )
Right down side you have mailbox ( or voice mail ) if you hit the button and no box is at the phone set, you´ll be asked, if you will creat one. hi t yes.
the passwort has to be "unchanged". the the voicemail key on a ua / dect set will blink and you will be teached on hitting the button for what you have to done.
on a SLI set you have ( in a star numbering pan ) type in *87 and the follow the voice to the mailbox menu.
I hope this is what yyou are looking for.
Return to “Configuration”
