nomadic feature
alexbrickwedde
nomadic feature
Post by alexbrickwedde »
has anyone already used the nomadic feature? We updated to r5.1 this week and i found some options regarding nomadic, but i did not found out how to use it. Help is not helpful. Do you have any advice on how to use it?
I found that:
- I can add virtual subscribers with option nomadic (which have very
few config pages)
- I can activate nomadic on central services page of a subscriber
- I can de-/activate nomadic mode (incl. a number) within pimphony
...Alex
dave.bolo
Nomadic Modus on OXO
Post by dave.bolo »
on my website you find a Docu how to program a Twinset between a internal subscriber and a GSM subscriber.
http://www.ip-pbx.ch under téléchargement _ omnipcx office
spring
Post by spring »
I just work a similar case. I just create a Virtual User without media and nomadic feature. Re-config. this Virtual User by actviate the nomadic mode. Running Pimphony Configuration Wizard and then manual enter this Virtual set number. Finally, assigning nomadic mode key and Cancel nodic key on Pimphony application
Return to “MAIN”
