Hi Guys,
I need your help.I have this incident in my system:
12/08/10 08:57:51 000001M|001/20/-/---|=2:4408=INT-IP Ethernet error code 4 (status 1 0 0x0a4 0x00 0x00)
How can i configure speed mode parameters in this coupler (INTIPB)?
Gracias.
Speed mode intipb
HI, when the card boots follow the below.......
When the message Hit ENTER key to suspend coupler boot processis displayed, press Enter to display the main menu:
IP configuration Menu
Available commands :
– view : display current IP configuration
– chmode : change IP Configuration Mode (Static/dynamic)
– chip : change Static IP Parameters
- chqual : Change default quality Parameters
– save : saved modified configuration
– reset : reset coupler
Use? or ? <cmd> to get help on Command
Config:
Enter chmode, then 1 to change the initialization mode to Static mode.
Enter chip and configure the following IP parameters:
The INT-IP B board IP address,
The IP subnetwork mask,
The router IP address,
The TFTP server 1 IP address,
The TFTP server 2 IP address.
Enter save to save the parameters.
Config:
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
mujib.alu
