Problems after install patch 42 for release 9 h1.301
nelson.vieira
Post by nelson.vieira »
I have installed patch 42 in my OXE R9.0 h1.301 and now i have some problems.
1 - Some times i cant login to the active CS with mtcl user with the error "Login incorrect". If i wait some time and try again i can login correctely. This problem does not apen in the stand-by CS.
2 - many incidents related to DHCP:
11/07/10 14:00:14 000001M|---/--/-/---|=5:1567=DHCP server started
11/07/10 14:00:44 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:01:14 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:01:44 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:02:13 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:02:43 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:03:13 000001M|---/--/-/---|=5:1567=DHCP server started
11/07/10 14:03:43 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:04:14 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:04:44 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:05:14 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:10:29 000001M|---/--/-/---|=5:1567=DHCP server started
11/07/10 14:10:59 000001M|---/--/-/---|=5:1567=DHCP server started
11/07/10 14:11:29 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:11:59 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:12:28 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:12:58 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:13:28 000001M|---/--/-/---|=5:1567=DHCP server started
11/07/10 14:13:59 000001M|---/--/-/---|=5:1567x002=DHCP server started
11/07/10 14:14:29 000001M|---/--/-/---|=5:1567x002=DHCP server started
The steps i used for patch installation were:
Patch Installation Procedure
1. Set up the loading tool (PC Installer)
2. Select Call Handling or Patch
3. Select the concerned drive contains dhs3mgr folder
4. Stop the telephone application in PCX
5. Go to swinst login
6. Expert Menu > Deliveries Installation
7. Select Install Delivery from the Server
8. Select the name of the server
9. Give the file path as /dhs3mgr/h130142
10. Wait for until End of Operation. Press Return!
11. Then we need to set the autostart
12. Start the telephone application
Return to “Software Loading”
