Hello
I have a problem on multiple PCs (OS=XP SP3) or is installed “My Instance Communicator”. Of the 350 computers in our network, there are a lot or the search area in the taskbar don’t work, when a name is written nothing happens ?!
Somebody already had this problem?
Thank you very much for your help!
Nb: sorry for my bad English :rolleyes:…
MyIc serach area don't work?!
Hello cavagnaro and thank you for your reply,
Unfortunately the problem still exists, I think the link between the search area and MIC application is breaks. If I want to close the search box that doesn’t work or if I disconnect and close the MIC, the search box is always present. I reinstalled the application on some computers but after a few days the problem returned, it's really strange...
For information Instant Communication Suite is version 5.1.000.583 and MyIc 1.8.003.003 ...
If you have any other suggestions ...
Thank you
Thank you
if search bar appear when myic has not yet started (icommunicator.exe)
consider it as a fake search bar
close icommunicator.exe
in botom right of windows desktop screen contextual menu (right click)
select tool bar
and uncheck myic
relaunch then myic ,
the displayed search bar will become the one launched by myic exe file running and not a fake task bar
select tool bar
and uncheck myic
corwin wrote:if search bar appear when myic has not yet started (icommunicator.exe)
select tool bar
and uncheck myic
Agree, many times this will help
