Fax Server Integration with Outlook 2007
selectkannan
Post by selectkannan »
Hai,
I installed fax server in Bics Environment. IN fax server i am able to send & receive faxes for individual users. Now i want to do integrate with Outlook. In exchange server we have done settings as per document. but still i am not able to send & receive faxes through outlook.
anticipating for reply.
Thanks,
agiftel
Post by agiftel »
Me Too, someone has some IDea??
What error do you get??
agiftel
Post by agiftel »
Hi, I have some bad/good news. I made some test and I get the attacched error only using outlook 2007. If I use outlook 2003 everything works fine. Do you some idea?? I cannot understand how "outlook's form" works; I mean where does it catch the email account for sending fax. Can you explain it?
Return to “OmniTouch 8450 Fax Software”
