Problems witch Patch 8.01 150335c
lugonsa
Post by lugonsa »
I need his support,
Since I load the patch g150335c
Of 8.01 be reread this one appearing the following mistake Routing problem, sending the incidents where one presents this message, thank you for his support
03/06/10 01:38:39 001001M|003/20/-/---|=3:4401=Ethernet broadcast reception disa
bled due to excessive traffic
03/06/10 03:00:02 001001M|---/--/-/---|=3:0433=PCS 10.36.201.73: Database update
: error 3 info -1.
03/06/10 03:00:09 001001M|---/--/-/---|=3:0433=PCS 10.36.201.107: Database updat
e: error 3 info -1.
03/06/10 03:00:10 001001M|---/--/-/---|=3:0433=PCS 10.36.201.41: Database update
: error 3 info -1.
03/06/10 03:00:20 001001M|---/--/-/---|=3:0433=PCS 10.36.202.41: Database update
: error 2 info -1.
03/06/10 03:00:20 001001M|---/--/-/---|=3:0433=PCS 10.36.203.73: Database update
: error 3 info -1.
03/06/10 03:00:21 001001M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : fe
ature incident 77 0
03/06/10 03:00:23 001001M|---/--/-/---|=2:0275=ACCOUNTING: Appli ACCOUNTING : fe
ature incident 77 1
03/06/10 03:02:41 001001M|---/--/-/---|=4:0428=CS->PCS: @IP 10.36.202.73 error 0
PCS domain 5
03/06/10 03:02:41 001001M|---/--/-/---|=2:0429=PCS 10.36.202.73 is activated
03/06/10 03:03:57 001001M|---/--/-/---|=3:0433=PCS 10.36.202.105: Database updat
e: error 3 info -1.
03/06/10 03:04:34 001001M|---/--/-/---|=4:0428=CS->PCS: @IP 10.36.204.73 error 0
PCS domain 11
03/06/10 03:04:34 001001M|---/--/-/---|=2:0429=PCS 10.36.204.73 is activated
03/06/10 03:05:44 001001M|---/--/-/---|=3:0433=PCS 10.36.203.41: Database update
: error 3 info -1.
03/06/10 03:06:33 001001M|---/--/-/---|=4:0428=CS->PCS: @IP 10.36.203.105 error
0 PCS domain 7
03/06/10 03:06:33 001001M|---/--/-/---|=2:0429=PCS 10.36.203.105 is activated
03/06/10 03:10:31 001001M|---/--/-/---|=4:0428=CS->PCS: @IP 10.36.202.73 error 1
PCS domain 5
03/06/10 03:10:31 001001M|---/--/-/---|=5:0430=PCS 10.36.202.73 is disabled
03/06/10 03:11:50 001001M|---/--/-/---|=4:0428=CS->PCS: @IP 10.36.204.73 error 1
PCS domain 11
03/06/10 03:11:50 001001M|---/--/-/---|=5:0430=PCS 10.36.204.73 is disabled
03/06/10 03:14:14 001001M|---/--/-/---|=4:0428=CS->PCS: @IP 10.36.203.105 error
1 PCS domain 7
03/06/10 03:14:14 001001M|---/--/-/---|=5:0430=PCS 10.36.203.105 is disabled
03/06/10 08:25:32 001001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
03/06/10 08:27:01 001001M|---/--/-/---|=0:1721=Phone exc 0, PC 0x082f89aa neqt 2
475
03/06/10 08:30:32 001001M|---/--/-/---|=4:0274=DTMF receiver release error
03/06/10 08:41:01 001001M|---/--/-/---|=4:0274=DTMF receiver release error
03/06/10 08:49:13 001001M|003/19/0/000|=3:4104=outgoing VPN Overflow call aborte
d No 34 12965
03/06/10 08:49:41 001001M|019/00/0/000|=4:4105=VPN ovf call failed because of VP
N time-slots on 1
03/06/10 08:49:41 001001M|019/00/0/000|=4:4108=VPN call failed: err 143N NL 1>2
eqt 203
03/06/10 08:49:51 001001M|019/00/0/000|=4:4105=VPN ovf call failed because of VP
N time-slots on 1
03/06/10 08:49:51 001001M|019/00/0/000|=4:4108=VPN call failed: err 143N NL 1>2
eqt 203
03/06/10 08:51:28 001001M|019/00/0/000|=4:4105=VPN ovf call failed because of VP
N time-slots on 1
03/06/10 08:51:28 001001M|019/00/0/000|=4:4108=VPN call failed: err 143N NL 1>2
eqt 2307
N time-slots on 1
eqt 213
03/06/10 08:51:32 001001M|019/00/0/000|=4:4105=VPN ovf call failed because of VP
N time-slots on 1
03/06/10 08:51:32 001001M|019/00/0/000|=4:4108=VPN call failed: err 143N NL 1>2
eqt 384
03/06/10 08:51:34 001001M|019/00/0/000|=4:4105=VPN ovf call failed because of VP
N time-slots on 1
03/06/10 08:51:34 001001M|019/00/0/000|=4:4108=VPN call failed: err 143N NL 1>2
eqt 213
03/06/10 08:52:39 001001M|003/19/0/000|=3:4104=outgoing VPN Overflow call aborte
d No 34 12965
03/06/10 08:53:54 001001M|---/--/-/---|=4:0274=DTMF receiver release error
03/06/10 09:00:01 001001M|019/00/0/000|=4:4105=VPN ovf call failed because of VP
N time-slots on 1
03/06/10 09:00:01 001001M|019/00/0/000|=4:4108=VPN call failed: err 143N NL 1>2
eqt 1609
03/06/10 09:00:50 001001M|001/07/0/000|=4:4105=VPN ovf call failed because of VP
N time-slots on 39 0
03/06/10 09:00:58 001001M|001/07/0/000|=4:4105x004=VPN ovf call failed because o
f VPN time-slots on 39 0
03/06/10 09:00:58 001001M|---/--/-/---|=4:0274=DTMF receiver release error
03/06/10 09:01:00 001001M|001/04/0/000|=3:4099=B channel choice error No 25 link
38 out 0
03/06/10 09:01:01 001001M|001/04/0/000|=3:4099=B channel choice error No 19 link
38 out 0
03/06/10 09:01:02 001001M|001/04/0/000|=3:4099=B channel choice error No 23 link
38 out 0
03/06/10 09:01:14 001001M|001/04/0/000|=3:4099=B channel choice error No 25 link
38 out 0
03/06/10 09:02:57 001001M|001/04/0/000|=3:4099=B channel choice error No 26 link
38 out 0
03/06/10 09:07:05 001001M|001/16/-/---|=0:3770=Func.Err. T=1 M=0x44 E=3 (#255) s
=255,R=0x18, 0x00c 0x000
03/06/10 09:07:05 001001M|001/16/-/---|=4:3536=Routing problem
03/06/10 09:08:19 001001M|003/19/0/000|=3:4104=outgoing VPN Overflow call aborte
d No 34 12965
d No 34 12965
03/06/10 09:08:19 001001M|019/00/0/000|=4:4108=VPN call failed: err 143N NL 1>2
eqt 3154
03/06/10 09:08:41 001001M|003/19/0/000|=3:4104=outgoing VPN Overflow call aborte
d No 34 12965
03/06/10 09:10:43 001001M|---/--/-/---|=4:0274=DTMF receiver release error
03/06/10 09:18:22 001001M|---/--/-/---|=4:0274=DTMF receiver release error
03/06/10 09:19:26 001001M|012/--/-/---|=2:2043=Loss of the 12 CRYSTAL
03/06/10 09:19:26 001001M|012/00/-/---|=2:2042=Loss of a GD type cpl
03/06/10 09:19:26 001001M|012/02/-/---|=2:2042=Loss of a UA type cpl
03/06/10 09:19:26 001001M|012/04/-/---|=2:2042=Loss of a UA type cpl
03/06/10 09:19:26 001001M|012/05/-/---|=2:2042=Loss of a Z type cpl
03/06/10 09:19:26 001001M|012/06/-/---|=2:2042=Loss of a NDDI type cpl
03/06/10 09:19:26 001001M|012/27/-/---|=3:2490=Loss of a virtual coupler GPA (12
,27) of the associated coupler GD (12,0)
03/06/10 09:21:01 001001M|---/--/-/---|=4:0274=DTMF receiver release error
03/06/10 09:23:36 001001M|012/00/-/---|=4:0740=Beginning of an INT/IP downloadin
g @:00.80.9f.89.66.3e (binmg)
03/06/10 09:23:37 001001M|012/00/-/---|=5:0741=End of downloading of an INT/IP b
oard @:00.80.9f.89.66.3e (binmg)
03/06/10 09:23:50 001001M|012/00/-/---|=4:0740=Beginning of an INT/IP downloadin
g @:00.80.9f.89.66.3e (binmgrdimg)
03/06/10 09:33:22 001001M|003/23/-/---|=0:3770=Func.Err. T=1 M=0x44 E=3 (#255) s
03/06/10 09:33:22 001001M|003/23/-/---|=4:3536=Routing problem
03/06/10 09:36:09 001001M|019/00/0/000|=3:1304=Distributed call with unknown ini
tial type 0, desti 1
03/06/10 09:36:41 001001M|---/--/-/---|=4:0274=DTMF receiver release error
03/06/10 09:39:03 001001M|001/04/0/000|=3:4099=B channel choice error No 14 link
38 out 0
03/06/10 09:41:19 001001M|001/07/0/000|=4:4105=VPN ovf call failed because of VP
03/06/10 09:41:49 001001M|001/07/0/000|=4:4105x009=VPN ovf call failed because o
03/06/10 09:41:56 001001M|001/07/0/000|=4:4105x004=VPN ovf call failed because o
03/06/10 09:41:56 001001M|001/07/0/000|=3:4099=B channel choice error No 5 link
39 out 0
03/06/10 09:43:41 001001M|012/00/-/---|=5:0409=The inter-ACT link over IP from (
19 1) is up
03/06/10 09:43:44 001001M|012/00/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot
2
03/06/10 09:43:44 001001M|012/00/-/---|=0:5859=MG/RGD: download status 2
03/06/10 09:43:53 001001M|012/02/0/000|=5:2053=Terminal 0 in service
03/06/10 09:43:53 001001M|012/02/0/001|=5:2053=Terminal 1 in service
03/06/10 09:43:58 001001M|012/02/0/001|=5:2053=Terminal 1 in service
03/06/10 09:43:58 001001M|012/02/0/003|=5:2053=Terminal 3 in service
03/06/10 09:43:58 001001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 ser
ies, type 18 (neqt 3475)
03/06/10 09:43:58 001001M|---/--/-/---|=3:1613=15.04.12.00.06.06.82.12.40.ff.00.
00.00.00.00
00.00.00.00
ies, type 13 (neqt 3475)
03/06/10 09:43:58 001001M|---/--/-/---|=3:1613=15.04.0d.00.02.02.82.12.40.ff.00.
00.00.00.00
00.00.00.00
00.00.00.00
00.00.00.00
00.00.00.00
03/06/10 09:43:58 001001M|---/--/-/---|=3:1613=15.04.0d.00.02.02.85.12.60.ff.00.
00.00.00.00
00.00.00.00
03/06/10 09:43:58 001001M|---/--/-/---|=3:1613=15.04.0d.00.02.02.81.12.00.ff.00.
00.00.00.00
03/06/10 09:43:58 001001M|---/--/-/---|=3:1613=15.04.0d.00.02.02.80.13.02.ff.00.
00.00.00.00
00.00.00.00
00.00.00.00
03/06/10 09:43:59 001001M|012/02/0/004|=5:2053=Terminal 4 in service
03/06/10 09:44:01 001001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 ser
ies, type 11 (neqt 3475)
03/06/10 09:44:01 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.80.11.00.ff.00.
00.00.00.00
03/06/10 09:44:01 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.80.20.00.ff.00.
00.00.00.00
03/06/10 09:44:01 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.91.20.10.ff.00.
00.00.00.00
03/06/10 09:44:01 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.84.20.40.ff.00.
00.00.00.00
03/06/10 09:44:01 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.84.20.50.ff.00.
00.00.00.00
03/06/10 09:44:01 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.82.20.80.ff.00.
00.00.00.00
03/06/10 09:44:01 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.8b.29.00.ff.00.
00.00.00.00
03/06/10 09:44:01 001001M|012/02/0/003|=5:2053=Terminal 3 in service
03/06/10 09:44:02 001001M|012/02/0/004|=5:2053=Terminal 4 in service
03/06/10 09:44:03 001001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 ser
ies, type 11 (neqt 3477)
03/06/10 09:44:03 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.80.12.00.ff.00.
00.00.00.00
03/06/10 09:44:03 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.82.12.40.ff.00.
00.00.00.00
03/06/10 09:44:03 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.88.10.30.ff.00.
00.00.00.00
03/06/10 09:44:03 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.82.12.10.ff.00.
00.00.00.00
03/06/10 09:44:03 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.80.11.00.ff.00.
00.00.00.00
03/06/10 09:44:03 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.80.20.00.ff.00.
00.00.00.00
03/06/10 09:44:03 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.84.20.40.ff.00.
00.00.00.00
03/06/10 09:44:03 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.82.20.80.ff.00.
00.00.00.00
03/06/10 09:44:03 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.8b.29.00.ff.00.
00.00.00.00
03/06/10 09:44:04 001001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 ser
ies, type 11 (neqt 3478)
03/06/10 09:44:04 001001M|---/--/-/---|=3:1613=15.04.0b.00.00.00.80.12.00.ff.00.
00.00.00.00
alaint73
Post by alaint73 »
Has these incidents started only since you applied patch 35 ? which patch did you have before? for me some of them seem normal like the 427 and 428 which indicated that your PCS is rebooting after an automatic scheduled pcscopy and some VPN calls failing..
elaborate more...
Alain
Patch installed only on CPU or PCS too?
alaint73
Re: Problems witch Patch 8.01 150335c
Post by alaint73 »
lugonsa,
any update on this? has the issue been fixed? if so, it would be interesting to share the resolution steps.
thanks
Return to “Software Loading”
